Willthese aluminium head guard protectors fit on my 04 R1150R? (these, part nbr. 71607658636, or from some other brand) I've seen them on the Gs's
After a very stupid accident in which the plastic protector broke giving almost 0 protection to the cylinder head, I'm seriously considering mounting one set of these. Anyone has them on the RR? Any pics?
Without putting too much time into research, my answer would be no. Those appear to be on a 1200GS "hex-head". They may fit on the 1200R but not the 1150.
yep, you're right. Not sure if they make it for the 1150, but they should. I saw the tourtech one, it's a bit "rough", not as elegant as the bmw one... I'll keep looking.
The Hepco Becker bars do really protect the heads, however if your a spirited rider you will find they grind. I bought some a couple years ago, and am now careful to not get into a corner to hard, mine are flat on the bottom I wish the Stanton protectors were still available.
Don
