I ordered two "cable guides" that attach to the front whell fender and fork, since the others rotted out. I have a 2004. The only way to feed the cable through the guides is by removing one end. Anyone have a suggestion on which side is easier to remove-- at speedometer or at wheel and if so, how to do this?
thanks,
Gene
Speedometer Cable
Re: Speedometer Cable
I suggest at the wheel, easier to access and remove
- Edmundo Amado
Hi, I did replace the the cable guides and remove the cable at the wheel end, it takes no more than 10 minutes.
