Quick Disconnect Fuel fittings
mauledrvr
Post by mauledrvr »
http://www.smallparts.com
No affiliation, just a source for stuff.
Part # QCB-05-01 which is 5/16" barb for 8mm fuel line. Solid brass with Buna-N
oring seals, nice quality.
One set each fuel line- for tank removal jobs. Two sets required per bike.
$28.00 total price shipped, that's two sets. Use the Sixty bucks saved on
a nice ride to lunch.
Happy New Year,
kc
PA Rider
Re: Quick Disconnect Fuel fittings
Post by PA Rider »
I need to do this upgrade. Does anyone know how well the Smallparts disconnect units compare to the CPC chrome plated brass quick disconnects sold at Beemer Boneyard?
2003 R1150R
Twempie
Post by Twempie »
PA Rider wrote:I need to do this upgrade. Does anyone know how well the Smallparts disconnect units compare to the CPC chrome plated brass quick disconnects sold at Beemer Boneyard?
I've installed Beemer Boneyard brasses. No problems, they're well built. PITA to remove those OEM clamps. Have patience... and Bandaids.
2003 R1150R Single Spark Non-ABS
duckdave
Donating Member #: 580
Post by duckdave »
I got the Omegas, and I'm quite satisfied with them. I read everything, and could get no clear picture of the consensus recommendation. I've also dealt with Small Parts for other unrelated parts; they are an excellent company and I'm sure their QDs would make you proud. There have been some recent (past year or so) "lower cost" entries into the market, including Beemer Boneyard (another excellent company!) and, believe it or not, BMW has a new/improved replacement that is competitive, cost-wise anyway. I think any of these would be a step up.
Re: releasing the OEM clamps. A small screwdriver (small enough to get into the raised portion of the clamp) vigorously applied in a prying motion in various directions within the clamp will generally loosen the clamp up sufficiently to remove. Don't forget to pry a bit on the inside-ends of the hoses to try and gain release from the QDs. The key to both of these releases is plenty of vigorous prying action in many directions, applied with some force, to loosen both the clamp and the hose.
-dd
-duckdave
'04 R1150R Silver
Little Rock 'n Roll
Double Lifer #580
gregor
Post by gregor »
Amazing prices. Was £130 in the UK for locally supplied Omegas when I checked last year.
PA Rider
Post by PA Rider »
duckdave wrote:The key to both of these releases is plenty of vigorous prying action in many directions, applied with some force, to loosen both the clamp and the hose.
-dd
DD...sounds like a joy. Maybe I'll double-up on my blood pressure meds before I try it.
Thanks everyone for the input.
PA Rider
2003 R1150R
snowprick
Donating Member #: 3953
Post by snowprick »
gregor wrote:Amazing prices. Was £130 in the UK for locally supplied Omegas when I checked last year.
gregor,
The people in UK get screwed every time. Things are no longer priced according to their real value, it seems to be based on what the vendor believes he can get for them. You might find it is cheaper to buy in the US and have them ship to you in UK.
A famous toothbrush manufacture sells German made toothbrush heads at £8.00 per pair in UK. In the Philippines the EXACT same item is £4.00.
My Hall sensor quit a while ago. The local Motorrad dealer told me the part would cost $500. I got one brand new from BeemerBoneyard for $230 + $40 shipping. It was in my hand 6 days later and fitted the next day for a nominal sum. Dont let them rape you, look around. The internet is a great leveler.
Rod
Apple Macintosh
maduko
Donating Member #: 735
Re: Am I Just Lucky?
Post by maduko »
I've never had any problem/complaints with the quick disconnects on my 2002. Were there good and bad OE versions?
owldaddy
Post by owldaddy »
maduko, if you have the stock plastic QD's and have not had a problem with them, then you have been very lucky indeed. Those will break at the most inopportune time and leak fuel all over your engine. I broke one on my 04 RR just disconnecting it. Lucky for me I was at home when it happened, and already bought the new brass replacements.
Don
rockstercliff
Post by rockstercliff »
I am very happy with the Omegas, at the time they were the only option posted in the BMW blogasphere. Mine did break one day, in 06, made do with a brass fitting barbed on both ends till the Omegas arrived. If you prefer the Buna or Viton o-rings, they are available at McMaster-Carr, a great company, for considerably less. Come to think of it, the fittings may be also.
maduko
Post by maduko »
owldaddy wrote:maduko, if you have the stock plastic QD's and have not had a problem with them, then you have been very lucky indeed.
Thanks. Mine do have some plastic as I recall.
I remember reading something about a recall on these, didn't know if that cured the problem or not.
I resisted abandoning the BMW black plastic QD's for years -until- my 6 year old set cracked open in my hands upon careful removal in my garage. After that I resisted again dropping the near $80 for the Qmega chrome plated brass QD's by employing 2 lengths of brass tubing. Then the leaky hassle of removal and a small cash windfall changed my mind. Wow! was it worth it !!! Those babies always slide together with smooth precision and look like they cost $200. I replaced the 6 year old rubber EFI fuel lines too. Total cost, almost $100 and less than an hour's time. Considering the $300+ wasted on the bike' insurance premium, it's money well spent.
The best part is . . . . no more worries ever again, especially when far away from home. What is that worth to you?
R4R&R
Donating Member #: 293
Post by R4R&R »
I finally ordered the brass QD's from BeemerBoneyard and should have them tomorrow. I guess I'm changing them this weekend!
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
