Uneven Blueing
snag
Donating Member #: 639
Uneven Blueing
Post by snag »
I've got one pipe that has blued materially more than the other. The first words out of my diesel mechanic bud when he saw the bike was "you've got one cylinder running hotter than the other." Makes sense; comments?
The bikes are in the barn, the batteries are on tenders, 5 months to go, does anyone know of a boxer sled? :( [-o<
'08 12R
'79 CBX
'74 CB750
Re: Uneven Blueing
I'd tend to agree with your mechanic friend. I'd be checking the valve adjustment as a first step.. then the TB balance.
BigEasy
Re: Uneven Blueing
Post by BigEasy »
I think Don is spot on with one caveate; if you let the bike idel to long in a warm-up you may get one side hotter than the other. I believe the left side will heat up before the right. I'm guessing if you don't warm the bike for very long, i.e. < a minute, Don's got your answer.
Currently:
07 R1200R
07 XB12STT
10 FLHTP
12 Wee Strom ADV
snag
Re: Uneven Blueing
Post by snag »
It's typically start and ride with little warm up. Will check both valves and throttle bodies in the spring.
Thanks.
'08 12R
'79 CBX
'74 CB750
