E-ZPass holder
BobbyLeBout
Donating Member #: 676
E-ZPass holder
Post by BobbyLeBout »
This bracket mounts just above the headlight.
This is the starting piece.
Then a square frame is added. The frame will be remade by cutting and bending one piece of aluminum angle.
Rivit the black plastic holder to the square frame
Paint it black and mount it
Clip the E-ZPass in place
I hope it reads when going through the chute.
Re: E-ZPass holder
It should work fine. Mine is tie-wrapped in about the same spot on my BMW Touring shield mounting bracket, and is also painted black to hide it. As long as the side facing forwards is the correct side (which yours is..) should work like a champ.
