Airfoil thingy?
famousperson
Sextuple Lifer
Donating Member #: 599
Airfoil thingy?
Post by famousperson »
What is the airfoil shaped thingy (I think that is the proper technical term) attached to the front fender brace, parallel to the forks (one on each side)?
'07 R1200R
Life Member #599
NAUI Inst. #1434 (since 1969)
BigEasy
Re: Airfoil thingy?
Post by BigEasy »
If I understand you correctly they are there to direct air to the oil cooler. What they are called? I dunno :-k
Currently:
07 R1200R
07 XB12STT
10 FLHTP
12 Wee Strom ADV
Graf
Donating Member #: 642
Re: Airfoil thingy?
Post by Graf »
it's to deflect air to the air cooler....as bigeasy said.......if you look at the manual, they specifically say not to remove them......however I have seen carbon fiber huggers without them....
08 R1200R
sandycruz
Re: Airfoil thingy?
Post by sandycruz »
I freak-out if I took them off.
But then again I use both a belt and suspenders.
David Giannini
Santa Cruz, CA
'07 R1200R Black
'99 R1100SA Black
'93 900SS Red -Sold-
RonR
Re: Airfoil thingy?
Post by RonR »
Mine are resting quietly in my R1200R parts box along with the carbon cannister, mirrors, etc. I, too, saw the catalog part for a CR mud guard (fender) without the airfoils, accompanied by a caption stating that they don't really do anything. So, off they came. The upper bolt, by the way, only holds the airfoil to the mudguard via a nut mounted in the mudguard, and is an ugly mole on the fender without the airfoil in place. The cosmetic solution came via a #16 cone washer (from my plumbing parts box) that fits perfectly over the fitting on the fender, held in place by the original bolt. A couple of days ago, I took a spirited ride through the local San Gabriel mountain roads in 85F weather and saw no difference on the panel. Still dead center.
