I'm going to install some Motolights on the front calipers. Can anyone provide the torque values for those bolts?
Thanks.
Torque Values - Caliper bolts
30 Nm (newton meters) for the calipers
8 Nm for the adjustment screw
Source : Jim Von Baden's R1200 Maintenance CD.
http://www.marcparnes.com/BMW_R1200_Mai ... _Video.htm
Note however that according to MotoLights website, you want to use the bike manufacturers recommendations for the brake caliper bolts when attaching your lights. On my R1150, it is 40 Nm - don't know if it is only 30 Nm on your R1200.
Torque values from BMW Maintenance CD
Here you go:
Front brake Brake disc to front wheel M8 x 25 -10.9, Replace screw Micro-encapsulated tighten by stages in diagonally opposite sequence Initial torque, 12 Nm Final torque, 24 Nm
Brake caliper to slider tube M8 x 32 - 10.9 30 Nm
Brake fitting bleed screw M5 2 Nm Bleed screw, brake caliper, front 5 Nm
Rear brake Brake caliper, rear, to final drive M8 x 25 24 Nm
Brake disc to wheel carrier M8 x 15.5, Replace screw Micro-encapsulated 30 Nm
Brake caliper, rear, bleed screw 5 Nm
MSF #127350 NAUI #36288
2011 RT
2011 RT
