Thanks in advance, cruiser
Hepco & Becker 'Journey 50' topcase mounting
If anyone out there has the subject topcase fitted to their R1150R, could you please tell me how you mounted the box? Did you use an adaptor of some description to mount the box on the original BMW plate, or did you use a Hepco & Becker carrier. Part numbers would be appreciated
Mike in Hamburg
ScooterCop
I used the Hepco rack for my 40 liter topcase.
http://www.eurotechmotorsports.com/form ... =1&Big=Yes
2004 R1150R ABS
2004 Piaggio BV200 (for work use only!!!)
BoiseBeemer
I have the 50-liter and it uses the same mounting hardware as Scootercop's 40 liter. Just use the solid and well-made H-B mount plate. It's relatively inexpensive and simply replaces the plastic BMW rack-plate and vertical struts with a steel plate and struts. You just swap the BMW bolts for the provided H-B kit--about a five-minute job.
It looks a bit more business-like than the original equipt, but not out of place, as Scooter's picture proves, and it carries the top case securely, with easy on-and-off. I've used mine all summer to carry up to thirty pounds of expensive camera gear to jobs and on vacation, and I have nothing but praise for it.
Edited addition:
Just reread the OP and noticed your request for part numbers:
Rack- 650.632.01.01
Cases--
Journey 50-liter black - 610.086 00 01
Journey 50-liter black/silver 610.086 00 09
Journey 40-liter black 610.088 00 01
Journey 40-liter black/silver 610.088 00 09
Edited addition:
Rack- 650.632.01.01
Cases--
Bruce Jones
2004 Silver Roadster
2004 Copper Rockster
1953 Platinum spouse
