magnetic tank bags?
magnetic tank bags?
I recently purchased a r1150ra. i am looking into tank bags and wondering if a the ones that attach magnetically work well on the tank?
does anyone have any experience with them? if so which one?
i see that on ebay they are selling new ones (no name brands) that seem like great deals. anyone have any experience with these?
thanks
thanks
BoiseBeemer
No experience with the EBay bags, but I have been using a magnetic Marsee bag for the past three seasons. I was initially concerned about the possibility of scratching the finish, but have not seen ANY sign of wear on the tank so far, and the positioning even during hard cornering or sudden stops seems to be so well fixed that I've never bothered to use the security harness that they all seem to come with. I do make sure that the tank is clean (or at least dusted) and that the bag doesn't pick up any foreign particles to scratch that beautiful Roadster finish. Apparently the clear coat on the 1150R is good stuff. I'm not sure I'd be as confident mounting it on my wife's matte-black Rockster tank, however.
Bruce Jones
2004 Silver Roadster
2004 Copper Rockster
1953 Platinum spouse
I've owned a few magnetic tank bags, and while I prefer not to use one at all, my favourite for small stuff like wallet, camera, visor cleaner etc is a small Joe Rocket 'Manta' (or something) that has 4 magnets.
One problem I did find with two other bags is that the shape of the tank and oil cooler panels makes two 'funnels' that sweep up and over the tank each side of the forks.
No problem, except that some magnetic tank bags have large flaps that sit over the sculptured indents at the side of the tank (forward end). The airflow (at speed) tends to get under the flaps and can move or lift the bag. Just watch for that. You need to try a bag on the bike and see if the flaps sit flat or arch over the channels in the tank.
Some brands are worse than others. Otherwise, they all seem to stick pretty well.
I bought a "MotoPak" brand from EBay a few years ago. I think I paid around $50 for it new. I think they've gone up a little, but still a good deal. I prefer to not use it on the tank except when needed (carrying lots of crap AND a passenger). It came with bungee hooks and four bungee cords, which I usually use to attach on the rear seat:
I've noticed after a while of using it on the tank, it starts leaving traces of the non-skid rubber padding from the botton of it.
Most magnetic bags will have some kind of safety lanyard to attach it to the bike in case it 'comes off'. Mine came off once on the highway - it just lifted up enough to let me know it was coming off, and I was able to save it with a free hand. I use the safety lanyard now when it's on tyhe tank.
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
I mount my magnetic tank bag on the rear seat also.....It can't scratch the tank from back there..
DJ
DJ
I recently bought one of these by Hein Gericke.
http://piratesk12site.net/Verholentankbag.htm
This is the link to Pirate's Lair, but if you're in Europe you can do like I did and get one direct from their German supplier:
http://www.verholen.de (thanks and credit to Jerry Finley for his suggestion)
Here is the relevant page: (in English)
http://www.mv-motorrad.de/lshop,showdet ... 26321,.htm
The fixing mechanism is great. As well as magnets, (four of - very strong) - it also uses two metal fasteners, locking to two studs which replace two of your filler cap screws.
I've done about 600 miles with mine, at speeds over 100 mph (on a private road of course), and it hasn't moved at all.
It's big enough for earplugs/neck warmer/mars bar/bottle of water/camera/phone/keys - all at the same time. Detaches easily for fill ups.
Note - a warning comes with the bag to suggest that the magnets are strong enough to wipe your credit cards - so I don't put my wallet in there.
2nd Note - the one for sale at English Hein Gericke stores is not quite the same. It looks the same, but doesn't have the fasteners, relying just on the magnets.
Hope this helps
Cheers
Hope this helps
Cheers
Trapper
Black '04 R1150R
Black '04 R1150R
I have the Marsee Corona which has the magnetic ring that permanently attaches to the tank, then mates bayonet-fashion with the botttom of the bag. The bag does not touch the tank. I have been very happy with it and the build quality is excellent. I did have the Big-Mak bag and did not find it very satisfactory YMMV.
- dragonmojo
I have the Chase Harper Manta on my Rockster; it holds very little because the bag is very small (I swear the height is less than 2"). I recently got the Joe Rocket Manta for the R1200C and it should fit the R1150R tanks quite well. It's a small to medium sized bag that holds just what you need for a ride, and then some. That means you can take your sandwich and soda with you too.
I use the lanyard just in case that gust of wind decides to get under the bag and pries it loose. No matter how strong the magnets, I've learned not to mess with Ma Nature.
I always ride with a tankbag, so I am not overly concerned with the tank's finish. Just make sure there's not dust on the tank (and bottom of the bag) when mounting. Or, they make those clear semi-adhesive sheets you can try and are probably thin enough not to affect the magnetic hold.
'04 R1150Rx (GRN)
'88 Hawk GT
'04 R1150Rx (GRN)
'88 Hawk GT
geogridshorthair
18 liter Marsee
I bought the Marsee 18 liter magnetic bag for my Ducati. It also works great on both my R1150R and the new R1200R.
It is only in the way when fueling. Easy to put on and off though.
I have stuffed it many times while running errands to the market for dinner. It always amazes me how much I can put into the bag.
The velcro wallet is great for insurance and reg cards.
I paid about $155 for the bag at the Ducati dealer in southern CA.
Very happy with the bag.
02 Ducati S4 Nakid Sex on two wheels
04 Ducati ST4s w/abs WAY RED
07 BMW K1200R Sport
07 BMW K1200R Sport
I use a RKA magnetic tank bag and it works perfectly on the Roadster.
The only "problem" is that it is bright red as I had it custom ordered to match a '98 Honda VFR800 I used to have, and my Roadster is Black.
2002 BMW R1150R
2004 Honda CBR600RR
2006 Kawasaki KLX250S
2008 Ducati Hypermotard
1996 Ducati 900SS
2004 Honda CBR600RR
1996 Ducati 900SS
I used to use the Marsee tear drop magnetic bag and had no problems with it either scatching the tank (keep the underside clean!) or coming off at speed. I currently use a Held magnetic and it works great also.
I prefer a tank bag to a tail bag. I always have hard enough time lifting my leg over the seat when I have camping gear strapped on the back, I can't imagine having to do it all the time!
Vann - Lifer No. 295
- priapismic
I've been using this Oxford Humpback Magnetic tankbag for about three years and 30,000 miles, with never a problem moving. It's exandable, has a convenient carry handle attached, and even has shoulder straps to convert it to a backpack, if you so desire. They come in different colors, too, but I thought the silver matched my R pretty nicely.
To prevent any possible scratching of the tank, I put some Snider's Paintguard http://www.aerostich.com/catalog/US/Sni ... 16210.html on the tank, plus I place a piece of rubberized shelf liner material under the bag for extra insurance against scratching. Never been a problem.
I am currently using Vann's Marsee mag tank bag and have no problems with paint.wncbmw wrote:I used to use the Marsee tear drop magnetic bag and had no problems with it either scatching the tank (keep the underside clean!) or coming off at speed. I currently use a Held magnetic and it works great also.
Used a Chase Harper for about 8 years on 2 bikes.... No problems.
The trick is to lift, not pull....
I have the same small tank bag Trapper has. Works great within its limitations and doesn't get in the way.
I also have a semi-rigid tank bag (Axio) that I use like DJ does.... strapped to the back seat for longer daytrips where I bring contingency supplies like raingear, etc. It looks rather sleek. I can put it on the tank if the mood strikes me.
Axio tankbag
Axio tankbag
2005 R1150R -- Granite Grey Metallic
Lifetime Member #566
I've been using the "standard" Nelson-Rigg magnetic tank bag, mostly because it is fairly small (13x9x5 but can expand 4" if needed) but also because it was inexpensive (~ $40). It's actually reasonably well made, with some nice features including an organizer inside for keys, notes, cell phone, pens, etc and has a detachable map pocket. The magnets are quite strong and the bag hasn't ever shifted, even at triple digit speeds, over the 5,000 or so miles I've used it. The walls are semi-rigid, so it holds its shape. On the minus side, photocopied text tends to stick to the clear plastic on the map packet and you've got to use the raincover in the wet (but the cover pretty much does make things waterproof).
'03 R1150R
Life member 365
Errabundi Saepe, Semper Certi
Life member 365
Daryl_stamp
Simplicity is good, about $18 US
I picked this up at a POLO store in Neckarsulm last fall. I've got about 2500 miles with it so far and no complaints; other than that I had to cut out the side wall stiffener to allow it to conform to the contour of the tank. Usually holds just my camera, memory sticks, batteries, shampa, spare gloves, maps, hairbrush for MLW (My Lovely Wife) and lens cleaner packs.
[/img]
I think their website is something like POLO.DE
[/img]
- frozennorth
Just picked up a Bags-Connection Engage XL for Mrs North, from Twisted Throttle. German designed, made offshore someplace, and pretty innovative. Lot's of little pockets and one on top for your cell. They also have a GPS module that connects to the front of the bag.
Interesting way of mounting---the bag mounts to a ring that's bolted to the gas filler cap ring, then the matching ring connects to this via a quick disconnect. Really solid, easy to install, and no contact with the paint whatsoever.
Nice alternative to straps or magnets. I'm thinking of getting one to replace my BMW tank bag. They're also pretty affordable at under $200.
Check out this link of one on an R . . .
http://www.twistedthrottle.com/imagecat ... /2131/569/
Red 02, R1150R
Member # 506
I am an empty hospital!
Member # 506
