Bob... the shifter is made by Pingel. Pingel makes a kit for all Harley Models, the VTX Hondas, and a few others. The Pingle Shifter is a universal kit on my bike. It's electric and come with a shift module. Also a kill module designed to kill the motor through the coil then shifting. The kill module was not wired in on installation. I use the clutch to shift. And I have a up and down switch or button on the handlebars between the grip and the dim / bright switch. All the electronics are under the seat and use little space. The shifter is rock solid after 18k...if I let the motor idle down at a stop light and shift from 2nd to 1st the trans goes into neutral. A few revs and the trans pops into 1st when the switch is activated. Pingel is easy to do business with.Bob Ain't Stoppin' wrote:Hi Redwing! Can you tell us about that power shifter on your bike?
It works good.
http://www.pingelonline.com/index.htm
Robert
