BMW lubricants 101
Beemeridian
Donating Member #: 477
BMW lubricants 101
Post by Beemeridian »
456
2015 Honda PCX150
taosports
Post by taosports »
The service manual PDF I have shows BMW recommending Shell Retinax EP2
http://www.shell.com/home/Framework?sit ... x_ep2.html
def38
Post by def38 »
The BMW side and center stands will tolerate any reasonable general purpose grease...either lithium or calcium soaped grease. But, do clean the side stand switch routinely. I use a copius spray with WD-40 or some other spray GP lube/solvent. The switch gets loaded with dirt which can cause a failure. Oh, I use the WD-40 to lube the side and center stand as well....forget the grease.
But, during winter riding, make sure you remove salt from this area...especially the side stand switch.
Beemeridian
345
2015 Honda PCX150
mcollect
Post by mcollect »
Once again, WD40 is not a lubricant! When I worked at a gun shop, the owner thought it was an oil, he found that his blued guns rusted faster with WD40 then without, it cleaned all the oil off. Use it to clean and remove crud and water then use a lubricant such as lithium grease.
Michael
MG 78 LeMans
78 R100S
single650
Post by single650 »
What cleaned the oil off was the delivery solvent that the WD40 is disolved in, as that evaporates it leaves a film of WD40 behind which is a dry lubricant.
'03 R1150R Rockster
'94 K75s
def38
Post by def38 »
mcollect wrote:Once again, WD40 is not a lubricant! When I worked at a gun shop, the owner thought it was an oil, he found that his blued guns rusted faster with WD40 then without, it cleaned all the oil off. Use it to clean and remove crud and water then use a lubricant such as lithium grease.
WD40 is mostly Stoddard Solvent (~50%). It has very little in the way of lubricantion properties...it is more a cleaner that a lubricant...but, not a bad thing if used properly.
