loom failure
loom failure
Over the last week or so I have had an intermitant problem with not being unable to cancel the indicators on my '04 R1150R (Australian model). I recalled reading some riders having premature switch failure because, like me, they tend to cancel the indicators more than necassary just to be safe.
However, yesterday I noticed that if I held down the indicator cancel switch and turned the bars the switch worked reliably. Hmmm - thinks - that seems like a wiring loom problem. I quickly traced the fault to where the loom bends around the steering head and heads rearward. I sliced open the outer cover and found a nearly broken brown wire which is obviously the switch lead. An easy repair and problem fixed.
So - have a look at where your wiring loom wraps around the right hand side of the steering head. If it is tight when on full lock cut the cable ties and reposition it.
Easy as.
Easy as.
- CycleRob
desmophil,
I see you're new here with 5 posts, but the problem you experienced and solved is an old one to the group. It's good you spoke up. You were lucky it was only the signal cancel circuit and not one that cuts the engine off.
Your advice to cut the overly restrictive ziptie restraints was, besides being correct, shows that the factory, or more accurately, the assembly line, doesn't always do the right thing. I cut several harness restraining zipties in 2001 on both sides so at least a 12" long large radius loop (on both sides) is able to hang free when the steering goes lock-2-lock. Even though it is not restrained, there are no harness pinching or chaffing issues as you'll see when you turn the steering to the locks.
DJ Downunder
Cyclerob
1) Using zip ties on a 10K bike !!!
2) Not allowing sufficient slack for not to pull/flex the wires against a stop (the zip tie)
If you remember all the bikes of yesteryear had the metal zip ties of the rubber band variety, never too tight and fairly far appart. Yes most of the looms had quite a bit of movement and didn't look too tidy, but there was never an instance of cut wires, at least during my tenure.
The real shame is the Teutonic arrogance in regards to all these little "they all do that" , as the majority of the issues have been documented time and time again and the blatant ignorance/lack of work ethic of some techs within the dealer organization.
Ooops is 2008 and one of my new year resolutions is to call it like I see it (I think this is going to be a terrible year for me). I would expect that such comments will land me into one of two categories.,,....he is an old geezer or he is senile.....goody, that let's me get away with it.
You are being quite nice, IMHO the issue here is that who decided on the ties and routing was cutting costs and didn't quite now what he/she was doing.The factory made an error in judgment that must be corrected.
DJ Downunder
Once again, CycleRob, you are invaluable to this board.CycleRob wrote:I came across this pic in the R1150R manual and added text and red arrows to show the ZipTies that must be cut to avoid certain wire harness failures.
One of the first 'mods' I did to my bike when I bought it new, was cut the tight zipties and put new ones on that weren't so restrictive. Thanks to everyone on this board that mentioned that one years ago!
No way - that would cost BMW too much! I think manufacturers only issue recalls when they are forced to, or it's an obvious safety issue that would cause them real bad publicity.DJ Downunder wrote:I'm a bit pissed off with BMW that they did not do a recall about this obvious and common problem...
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
While I don't think BMW has had a recall for this problem, my dealer told me they made a plastic clip guard available that snaps onto the headpost to prevent wire chafing there. However, I don't think this will solve the problem of zip-ties cutting into the wire loom, so I did what Cyclerob suggested and wrapped those wires in tape and plastic loom as well. This seems to be working!
ADIOS!
ADIOS!
When I went in for the recall on the fuel line a couple of years ago, my dealer told me that there was a service bulletin out regarding the wiring loom and they did that also.DJ Downunder wrote:I'm a bit pissed off with BMW that they did not do a recall about this obvious and common problem...![]()
2002 BMW R1150R
2004 Honda CBR600RR
2006 Kawasaki KLX250S
2008 Ducati Hypermotard
1996 Ducati 900SS
2004 Honda CBR600RR
1996 Ducati 900SS
boxermania wrote:Cyclerob
You are being quite nice, IMHO, the issue here is that whoever decided on the ties and routing was cutting costs and didn't quite now/understand what he/she was doing.The factory made an error in judgment that must be corrected.
Ooops is 2008 and one of my new year resolutions is to call it like I see it (I think this is going to be a terrible year for me). I would expect that such comments will land me into one of two categories.,,....he is an old geezer or he is senile.....goody, that let's me get away with it.![]()
I cut a lot of zip ties over a year ago - all that looked restricting, and yet......... when I got to Arkansas and had CycleRob take a look at my bike, I had missed a couple of the important ones. I think the only zip tie on my bike right now is the one holding that throttle rocker cover/guard on my bike!!! I didn't want to lose another one of those! (it's still holding)
Kristi
05 Granite Grey
05 Granite Grey
I think the bulletin from the dealer is regarding the O2 sensor and ignition. There was a recall on that wiring, which was how the O2 sensor wire was routed down to the catalytic converter.Oilhead wrote:When I went in for the recall on the fuel line a couple of years ago, my dealer told me that there was a service bulletin out regarding the wiring loom and they did that also.
allanj255
You are correct John. Apparantly the "electric pulse" from the O2 sensor wiring caused the ignition to cut out intermitently. I was nearly wiped out at a junction on my 1150R when the engine died without warning when I was half way across the junction. I put it down to "rider error" due to getting used to a new bike, then I got the recall notice 1 week later from BMW. Here is the recallR4R&R wrote:I think the bulletin from the dealer is regarding the O2 sensor and ignition. There was a recall on that wiring, which was how the O2 sensor wire was routed down to the catalytic converter.Oilhead wrote:When I went in for the recall on the fuel line a couple of years ago, my dealer told me that there was a service bulletin out regarding the wiring loom and they did that also.
Models: BMW R Model Motorcycle Year: 2003
Number Potentially Involved: 7,000
Dates of Manufacture: December 2002 – August 2003
Defect: On certain motorcycles (Opposed Twins w/Two-Spark Ignition), the electrical wiring for the oxygen sensor and the ignition lead for the right-hand secondary spark plug have a parallel routing over part of their installation path. The close proximity of these cables may allow the signal from the ignition lead to interfere with the signal from the oxygen sensor wiring. As a result, engine hesitation or misfiring could occur, which could result in a crash.
Remedy: Dealers will re-route the electrical wiring to the oxygen sensor. The manufacturer has reported that owner notification is expected to begin during December 2003. Owners may contact BMW at 1-800-831-1117, Option #4.
Allan
2003 R1150R Twin Spark, (Black - the fastest colour)
This service bulletin was indeed for the wiring harness chafing. They checked the wiring harness for any signs of chafing, reroute if necessary, then installed a wire edge protector kit.
The service bulletin # is: SIB 61 004 06 054 TC R1150R INSTRUMENT C
The part # for the edge protection is: 51467019965
2002 BMW R1150R
2004 Honda CBR600RR
1996 Ducati 900SS
2004 Honda CBR600RR
1996 Ducati 900SS
Re: loom failure
I hate to dredge up old threads but it seemed pertinent.
Oilhead, would this be the same TSB of which you speak? If so it would seem that the newer models would not be afflicted with this particular problem. I looked at the wiring harness on my 04 model and the wire ties do not appear to be at the same locations as the diagram above......
NHTSA Item Number: 10001642
Service Bulletin #: 6200103
Replacement #:
Vehicle/Equipment Make: BMW
Vehicle/Eqipment Model: R1150R
Model Year:
Mfg Component Code: 034200 SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:HOSES, LINES/PIPING, AND FITTINGS
Date of Bulletin: 2003-05-01
Date Added: 2003-06-17
Summary: INSTRUMENT CARRIER CHAFED BY BRAIDED BRAKE HOSE. *TT
Neal
Replacement #:
Model Year:
Neal
'81 R65
'04 R1150R
'04 R1150R
Re: loom failure
I cut the ties at the steering head shown in Cyclerob's diagram when I got my 2002 about 6 months ago. A tip for anyone that does is to check that the left hand side loom doesn't then rub against the horn wiring plug, unfortunately I thought mine would be OK , but alas has now broken the horn wires. Should be an easy fix, and I'll possibly rotate the horn so that the clash is reduced.
'02 R1150R, Wellington NZ
Re: loom failure
I found that even after cutting those ties, the loom was still bending mostly at the kink that was created while the ties were still on. To prevent that I took about a 4-5 inch length of cable tie (about .25 inch wide one) and taped it to the outside of the loom. It acts like a spring and prevents it from kinking in that same spot, over and over again.
