This makes the most sense to me.def38 wrote:Doesn't really matter to me....I do know that when my oil gets hot (7-8 bars), I increase RPMs to circulate oil at a higher rate (more trips through the cooler)...I have nothing more to say about it.
Trapped oil.again?
The bars (LCD display) on the RID at the left on the GS indicate relative oil temperature. The only indication of pressure is the red light showing pressure or lack of it. And yes, your calculation bars to PSI is about right...Cheersgregor wrote:7-8bars (bar?) is a measure of pressure and equates to ~ 116psi.
Seems a bit high for oil pressure.
When I have nursed a knackered car engine home, low revs and little throttle have kept the knocking at a minimum.
Buffalo Grove eh?...used to live at Aspen Drive and Penny Lane...OU812 wrote:This makes the most sense to me.def38 wrote:Doesn't really matter to me....I do know that when my oil gets hot (7-8 bars), I increase RPMs to circulate oil at a higher rate (more trips through the cooler)...I have nothing more to say about it.Increased air flow through the coolers would help.
