Exhaust can removal
rbertalotto
How about utilizing a small automobile resonator such as this?
http://www.aeroexhaust.com/import_resonator_ar25.html
Or This
http://www.aeroexhaust.com/nascar_tip_11100.html
Or This
rbertalotto
I ordered one of these.....built in resonator. $21
http://store.summitracing.com/partdetai ... toview=sku
I've not seen resonators before - looks promising.
After running stock for a year, I took off my endcan & ran it with an eBay exhaust tip & the cat in place for a few weeks without problems. I subsequently found a cheap used Remus endcan with a y-piece (to replace the cat) which I now prefer - you won't believe how heavy the cat is til you unbolt one!
I know there are problems running the stock endcan without the catalytic converter in place, but I'd presumed running the bike without either a cat or an endcan would be massively loud? Does it work okay?
rbertalotto
rbertalotto
Hi,hank wrote:Here are some pics of the tail pipe. ( The tail pipe is Halfords own brand not ripspeed and cost about £10, it is the bigger one of the two they have I think it is the 58mm diameter.)
Another benefit of this mod is it allows the fitting of a full size case from an RT.
It is well worth the investment of your time to take the can off and try it, I will be very surprised if you don't like the sound that your bike makes.
The sound will be deeper and a bit louder, but not loud enough to offend, I often return from work well after midnight and set out again at 7 am and my neighbours have never complained. (I have asked them to tell me if it bothers them, and if so I will reinstate the silencer.)
Also before I removed the silencer I had a few near misses with myopic pedestrians who walked out in front of me. Now when they step up to the kerb they hear me coming and look around.
Hank.
Slightly louder, Black R1150R
When i bought my bike it came with a full laser exhaust, i do like the look of hank's mod especially... looks neat.
Question:
Should i fit the laser exhaust or hanks style of mod.
Hank;
Did you buy the exhaust end and make it fit or was it specific for this.
Ray
Make it happen
DJ Downunder
- jeffbowman
Cans Off!
I've used the shield flip approach, a $7 tip from AutoZone, some 800 grit sandpaper to rough it all up, and VHT FlameProof Flat Black paint (parts baked in the oven per instructions on can). The charcoal cannister is gone too, with proper plugging (per another post).
10,000 miles of tonal and visual bliss since ...
[/img]
[/img]Jeff Bowman
Blue on Black '04 Rock
rbertalotto
rbertalotto
- jeffbowman
Thanks!
Yes, the headers with the VHT flat black. The head covers were with the DupliColor High Heat 1200 deg. I would recommend using the latter on the headers, as well, as it seems to be stickier and less scratch prone.
If anyone out there has powder-coated their exhaust i would be interested in hearing about that ...
Cheers,
Jeff
Cheers,
Jeff
Jeff Bowman
- jeffbowman
I've created a separate custom paint post in this forum with more pics of my bike and hopes of getting some additional Rockster examples ... http://r1150r.org/board/viewtopic.php?t=11021
Hope this helps. Let me know if you have any questions!
Jeff Bowman
