Hi people - I ride a R1150R and seem to get by with a once a week 50-60 km ride (I drive too and have a lovely Honda CB Sevenfifty). My BMW gel battery seems sufficiently charged to start the R the next week.
Would someone be able to answer a technical question - how long (in hrs) or how far (in kms) would I need to ride my R for it to be fully charged?
The answer would be very helpful. Thanks!
R1150R Battery Charging Question
Batteries have no emotional aspects when they have had enough they let
go, the longer that you own that battery the more chance you have of
experiencing their manners.
The charge rate is dependent on the state of the battery(volt/amps) when
the motorcycle is running possibly 10 amps for at least an hour if the
battery is low, if it is ridden regularly it will charge at 2-3 amps reducing
to 1 amp when the battery is almost fully charged as the battery internal
resistance increases when fully charged allowing less current to flow
which is sensed by the alternator regulator and backs off when required
its a fully automatic process and one which is difficult to ascribe a
time / distance figure to.
Tip : batteries are like babies they like to be kept warm and will last
longer for it.
We are all at the mercy of the battery manufacturers who will try to
ensure you buy a new one every 3-5 years.
longer for it.
Sounds like you need a trickle charger to maintain your battery. I got a 3 amp BMW charger with my bike that plugs into the accessory socket. Couldn't be easier.
I find that commuting 12 miles each way a few times a week keeps my battery up nicely. Our roadsters have far better charging output than many other bikes.
Rick
2003 R1150R: Silver
Lifetime Member #585
2003 R1150R: Silver
I keep a "gel programmed" trickle charger on mine whenever I am not riding and this still happens:
1. take off charger...start bike...NO brake warning light
2. drive 2 miles to get gas b/4 ride
3. re-start bike...WARNING LIGHT COMES ON
4. drive for about 30 minutes and re-start....LIGHTS OUT!
It seems like just one start causes enough of a power drain for the ABS system to not like it.
The original battery is 2.5 years (12K miles) old and has always been tended.
I think the battery may be nearing its life's end.
Robert_winter_1000
