I've bought the genuine BMW accessory socket. Found the blanking plug in the starter-motor shroud, removed the shroud BUT there no plug there.
Maybe I'm not looking hard enough, but I assume it should be pretty obvious (even to me). Apart from cables attached to the starter-motor, there is only once cable visible. This is secured in a plastic cleat and the end disappears in to a hole....
I have a 2002/06 R so maybe they weren't pre-wired for an accessory socket. Anyone have info about this?
Another accessory socket question
Martin - does the socket you bought have a fancy 2-pin connector on the end of the leads?
The wires that are on the bike are hidden "behind" the starter motor cables and you have to fineagle them out with a small amount of tugging. If you want, I can pop up to yours sometime and show you? (I live in W.Sussex).
Just had another 'hunt the cable' session. There's a group of cables behind the starter-motor. They are cable-tied although one of them loops back on itself.
Could this be the one? I did give it a tentative tug but don't want to break a cable and am even cautious about cutting the tie as it will be a b*gger to get another one on there as the space is not exactly palatial.
Maybe the earlyish Rs didn't have the cable? Seems strange that the SM cover has a blanking lug for the socket though.
scottdelamancha
Martin, in my '02 , the wire bundle for the accy plug was cable-tied up to the starter motor wire, above the solenoid. A little tricky to reach, but obviously there, and when I teased out the bundle, I could see the two conductor connector behind it. Hope this helps you find it because it is there...
ADIOS!
ADIOS!
Martin - if you're available TONIGHT, I'm going to be stopping at Boxhill (Dorking) at about 6:30 (ish) to meet some mates.
If you're inclined, pop over (Boxhill can't be too far from you if you're in Surrey), bring the correct Allen key with you though...
I'll be on the Rockster, just look for a guy coughing regularly. (
