I didn't want to hijack Rich_Hamilton's thread, but since I brought it up, here are some important things to know ($$) about batteries, esp. gel cells...
(The following is excerpted and modified for clarity from
http://www.batterystuff.com/tutorial_chargers.html)
"The gel cell's electrolyte is suspended by a silica additive that causes it to set up or stiffen. The recharge voltages on this type of cell are lower than the other styles of lead acid battery (including the AGM). This is probably the most sensitive cell in terms of adverse reactions to over-voltage charging. Gel Batteries are best used in VERY DEEP cycle application and may last a bit longer in hot weather applications.
If the incorrect battery charger is used on a Gel Cell battery poor performance and premature failure is certain.
Typical absorption voltage range 14.0 to 14.2 volts, typical float voltage range 13.5 to 13.8 volts.
Note about Gel Batteries: It is very common for individuals to use the term GEL Cell when referring to sealed, maintenance free batteries, much like one would use Kleenex when referring to facial tissue or "Xerox machine" when referring to a copy machine. Be very careful when specifying a charger. More often than not, what someone thinks to be a Gel Cell is really a sealed, maintenance free, or (possibly) an AGM style battery.
Flooded: This is the traditional engine start battery. The liquid electrolyte is free to move in the cell compartment. The user has access to the individual cells and can add
distilled water as the battery dries out. Popular uses are engine starting and deep cycle designs.
Typical absorption voltage range 14.2 to 14.5 volts, typical float voltage range 13.2 to 13.5 volts.
Sealed: This term can refer to a number of different constructions, including only a slight modification to the flooded style. In that case, even though the user does not have access to the cell compartments, the internal structure is still basically the same as a flooded battery. The only difference is that the manufacturer has ensured that a sufficient amount of acid is in the battery to sustain the chemical reaction under normal use throughout the battery warranty period. Very popular uses are engine start and limited starting/deep cycle applications.
AGM: The Absorbed Glass Matt construction allows the electrolyte to be suspended in close proximity with the plates active material. In theory, this enhances both the discharge and recharge efficiency. Popular usage includes high performance engine starting, power sports, deep cycle, solar and storage battery.
Typical absorption voltage range 14.4 to 15.0 volts, typical float voltage range 13.2 to 13.8 volts."
You'll note the absorption voltages of the gel cells are significantly lower than the sealed or AGM types (whereas the float voltages are higher), so a regular battery charger will (eventually) overcharge a gel-cell, and, as it says above, ruin it prematurely. The technique bhalley uses to limit the charge time probably prevents that.
Gel cell chargers use specially designed current/voltage ramping algorithms to ensure they will accept a full charge at rates these batteries can tolerate.
Note also that using a regular battery charger to charge an AGM style might not damage it, but won't fully charged it either.
Sorry for this lengthy post; may be more than you wanted to know, but it's worthwhile to understand that there
are differences between chargers, and using the wrong one can prematurely ruin a good battery and cause you an unnecessary expense (not to mention the time it takes to remove the tank to replace it
