Balancing Act part 2
bonehead
Post by bonehead »
Hello fellas. My apologies to renagade for borrowing his thread's title...
My RR's front tire is due for a change after about 12k plus kms. I've purchased a Metz Roadtec Z6 for the purpose. My concern is that there is no facility in my area for balancing cast motorcycle wheels. Some people I've talked to say balancing is not necessary. Some have recommended putting in tire sealants that act as balancers at the same time. Your thoughts & suggestions will be highly appreciated.
Post by DJ Downunder »
I would have it balanced by experts...any motorcycle dealer should be able to do it..there must be a bike shop nearby?..who will be fitting the tire?
bonehead
Post by bonehead »
thanks, dj, for replying. i'm planning to have the tire mounted in one of those auto tire shops with pneumatic machines. their mechanics claim they can do it, but i'll have to have my eyes glued to their work!... It's the balancing that's presenting as a problem. i was told that there's some sort of adaptor so that motorcycle wheels can be mounted on auto wheel balancing machines. do those adaptors even exist?
bonehead
Post by bonehead »
oh and. sure there are bike shops here, but mainly for underbones and small displacement numbers. i've asked around in these places and all i get are perplexed stares ("what do want to balance your wheels for?!?).
bonehead
Post by bonehead »
bonehead
Post by bonehead »
threebucks1996
Post by threebucks1996 »
You should get the tires balanced. I don't know if you are replacing both tires or just the one, but alot of cycle shops require a special adapter for the rear rim being that is a single sidearm mounted. I had to call several places around town before I found one that could do it. Good luck.
Buckster
'03R
taosports
Post by taosports »
I balance and mount my own wheels. If you don't mind spending the money, Marc Parnes makes a beautifully crafted balancer :
http://www.marcparnes.com/
bonehead
Post by bonehead »
taosports wrote:I balance and mount my own wheels. If you don't mind spending the money, Marc Parnes makes a beautifully crafted balancer :
thanks taosports! very interesting product. hmmm... considering there are no bike wheel balancing facilities hereabouts, i can earn some bucks with it too...
