To Go Or Not To Go
BITS806
Post by BITS806 »
It depends on the type of oil and the outside temp. If its real cold and your running a high weight oil it would be better to wait a few minutes. You would be surprised how long it can take for the oil to get around when its real cold.
Ian
Post by Ian »
u might want to open the garage door first!
My dealer told me, bit of choke, start bike, helmet on, gloves on, blinkers and brakes,close choke then ride off. Has failed me yet
Ian
yjleesvrr
Location: Blacksburg and Haymarket, VA/Basking Ridge, NJ
Post by yjleesvrr »
It depends on how cold it is. Below 25 deg. F, I warm up the bike for a few minutes until the engine hits 1800 rpm with the high idle lever on. Above 30, I start the motor and go right away. Somewhere in between, it all depends on how the planets are lined up.
Member #93, June 2002
'14 BMW R1200RT "Wethead"
'77 BMW R100/7 "Airhead"
Boxerboy
Post by Boxerboy »
Oi DJ, your right cylinder is running hotter than the left.:shock:
Best get it serviced. :wink:
Once you've done that, do it again, and take another picture to check their handiwork! :wink:
Cheers...and stay horizontal!
DJ Downunder
Post by DJ Downunder »
Boxerboy....It's not my pic..it's not my bike..I wouldn't do that to my baby..it's just some pic that I saved from a past post.
REDSTAN
Post by REDSTAN »
:roll: thats wat i said paul twist and goooooo :lol:
"DO the miles get the smiles" ? so many roads so little time. (silver is the fastest ok)
