Been back to look at that Rockster, Riceburner. Quick Poll?
Ah, you must have the gift of tongues Riceburner.
I went back to look again at the Rockster. It is one funky looking gargoyle and I still covet it, whatever I have read.
Any chance you guys could jot down the following to assist in my decision?
Bike model & year (Rocksters only)
Mileage
FSH or not
Owned from new or from ?
Any significant maintenance issue. (Im not bothered about the odd blown bulb, but durability of finish, engine/brake/fuelling/drivetrain failures are of interest)
Think this would be useful in general.
Regards
Richard
Mileage
FSH or not
Regards
Richard
2003 R1150RLE (Limited Edition) Rockster.
Purchased brand new in April '05.
Currently at 20,964 miles.
Do my own maintenance (except ABS system)- switched to synthetic engine oil at 600 miles. Other lubes to synth. at 12K.
Upgraded shocks to Ohlins last month.
<Yes. I've got the full service history> added
NO Problems. Minor or otherwise.
P
P
Re: Been back to look at that Rockster, Riceburner. Quick Po
I'll have to do this 3 times....
1)
Bike model & year (Rocksters only): 2004 (53 reg)
Mileage : 1198(ish)
FSH or not : yes
Owned from new or from ? : new
Any significant maintenance issue. (Im not bothered about the odd blown bulb, but durability of finish, engine/brake/fuelling/drivetrain failures are of interest) : Vauxhallitus.
2)
Bike model & year (Rocksters only): 2004 (04 reg)
Mileage : 45,000(ish)
FSH or not : yes
Any significant maintenance issue.: not in order (might miss one or two) :
Also the rear shock started to leak, but I can't remember when.
I should point out that I didn't pay for ANY of the above - it was all covered by the warranty. One of the benefits of doing high mileages with a new BMW.
I know it seems a lot - but that's 45000 miles on roughly 20 months, in ALL weathers, I only stop riding when it's physically impossible to stay upright (have ridden in snow before now), and the bike was cleaned when it was serviced.
3)
Mileage : 20,000(ish)
FSH or not : yes
Owned from new or from ? : 1200 miles.
I'm sure that's all going to look like a large amount of issues - but the way they have been dealt with by my dealer (part of buying into the BMW "family"), has been simply impeccable (apart from the last mentioned issue, but that was sorted to satisfaction).
I know for a fact that if I'd done that kind of mileage on my other two bikes (ZXR400 and Zephyr 550) I'd have had to replace about 5 chains (and sprockets), 2 camchains, a clutch, a few sets of cushdrives, 3 headgaskets and a tank! I treat my bikes pretty harshly (certainly when riding) and the BMW just keeps coming back for more!
1)
Mileage : 1198(ish)
FSH or not : yes
2)
FSH or not : yes
- 15380 Gearbox output seal
- 18339 clutch actuator rod fell out of alignment (no idea how)
- 22000~ Coil replaced (had forgotten about that)
- 24041 Crankcase breather replaced
- 27635 front forks and other bits replaced (paint bubbling)
- 36000 sw/arm pivot bearing tightened
- 37000~ Coils replaced
- 44751 gearbox output shaft splines sheared (possibly caused by wheelieing it the day before?? ahem...
- 45000~ Clutch & seals replaced
3)
FSH or not : yes
- 3900~ speedo playing up - sensor was replaced IIRC
thanks ironlady a, there has to be more than 2 owners here?
Only two rockster owners? Would like to see a few more responses..
Rog(UK) - Yorkshire Dales
irich,
welcome to the board
2004 Rockster Edition 80
30,000 miles and no problems. Honestly, it runs better now than 15,000 miles ago. So smooth.
Biggest issue I've had is that the paint on the right cylinder cover is bubbling up (very little). I am going to sand both covers and paint them black. WHFO (when hell freezes over).
The shocks are pretty much shot, though. I've done quite a bit of 2-up and keep it all the way tight. The ride still is nice compared to most bikes. I think I'll go for some aftermarket shocks pretty soon.
Like Riceburner, and most Rockster owners, I highly recommend this bike. A little low on HP, but it's got torque. Everyone who rides my bike are surprised at how quick it is 20-100mph. (I am too)
+Plenty of power for road use
+Handles very well
+Stops very well
+Durability is on par with any other bike I know
+Tours well
-If you pay for maintenence, it's kinda pricey.
Don't make your decision until you test-ride one. Good luck!
+Handles very well
+Stops very well
+Tours well
04 Orange Rockster
25000 miles.
What is FSH?
The only major problem that I have had with this bike is 60 year old women that dont watch when they are turning left across your lanes.
Hit her in the right rear wheel, and sort of bounced off to the left, and eventually landed on the right side. Damage was bent fork arm, shredded front fender, twisted lower telelever crossmember with the ball joint, scratched bag, scratched head cover, and a tiny ding on the head. All fixed now, except for my fender, backordered from ilmberger.
Had I not had a boxer motor, her car would not have had the rear fender torn open about 18 inches, and I would have broken my right leg. The antilock brakes helped too.
Far as problems, um, drive shaft seals covered by warranty, and a ever growing rock chip on my headlight cover.
Just buy the bike. You will enjoy it.
25000 miles.
What is FSH?
- jfslater98
Bike model & year (Rocksters only): Tiger Stripe 2004 (please note I bought it pre-registered January 2006 with 0 miles on the clock - i.e. spent 18 months in various shop windows)
Mileage : ~4700
FSH or not : yes
Owned from new or from ? : new (well technically it wasn't new, being dealer pre-registered ... but I was with 0 miles/never ridden)
Any significant maintenance issue: front shock died after 3 weeks from new, must have dried out during the 18 months hibernation, got it replaced FOC
Mileage : ~4700
FSH or not : yes
Richard,irich wrote:Ah, you must have the gift of tongues Riceburner.
Mileage
FSH or not
Regards
Richard
I have a 2004 rock, bought new with 36,000 on the clock. No maintenance issues 'cept headlight bulbs and a broken fuel quick disconnect. I've been to Canada and back to Florida on the mighty rockster.
Tony D
R75/5
R1150R Rock
R75/5
R1150R Rock
keep em coming
Thanks for the feedback and keep em coming .. its useful to get some facts.
Looks like it will take me a week to get my KSA bike licence so I've got some time before I take the plunge.
The rockster is shaping up pretty good at the mo. Heres a couple of pics of the landscape outside of Riyadh.. and no, I won't be taking a Beemer out here... its a long walk if you break down
