Hi,
recently my R1150R started to shift into the neutral from 1st gear if I kick the upshift too softly...is it normal or is the cluth going to kaput soon?
Mine is a 02 model with 50000km on it... thanks a lot in advance!
False shift into Neutral?
Mind if I ask what bike you had before the R?
I had this problem to begin with, turned out I was just changing too quickly and not smoothly enough. An old habit from riding my CBR, which had a much shorter throw on the pedal. I also found I wasn't pulling the clutch in all the way sometimes, another bad habit I got from Jap bikes, the CBR gearbox was pretty refined and didn't actually need the clutch most of the time, while the BMW's can be a bit more, erm... "agricultural" for lack of a better word!
I still do it every now and again, but old habits die hard! It's really just a case of adjusting. Can be embarrassing I know, especially when pulling away fast, couple of times now I've hit neutral and revved it up, then found second and got the front wheel up
- John I. Stephen
Thanks guys....
I was riding Japanese bikes all my life till I got this BMW...
What I did not make clear was I ahd no rpblems with the gear shift going into neutral from 1st gear till recently(So i can't really be my riding/shifting technique)
Also when I meant "soft" I meant relatively softer kick, not the kinda pressure you shift from 1st to Neutral.....
