Yeah,......i know,.....but man,.....the Corban is like "real" leather and oh so classic!
Mine in classic black with no welts or unnecessary stitching,......which is why i didn't want the heated seat. Extra stiching could pass more water should i get caught out in bad weather,......although i'll probably be getting a seat cover to carry in one of my saddlebags just in case.
I even got the leather side panals instead to the usual vinyl. While mine might eventually take a set and show a few wrinkles at the sides,.......i'd much rather have "character" than,.....well,.....vinyl.
The Corbin is also more solid feeling and, well, after spending $730 with shipping,.... just has to be something i'll get used to.
Oh, and it real leather!
Seriously,.....i was also impressed with the tight fit of the Corban seat to the gas tank,......almost a squeegy fit. Still a bit firmer than i expected,.....buy that's "supposed" to get much better with a few thousand miles under me.
To top it off,......i just won a Corbin like new backrest off ebay that i should get in a day or two.
hep303 wrote:Hey joejeweler,
I am similar in stature to you and I also have the Corbin seat. I switched back to the original though. The Corbin seat raises you up about an inch and it is a little wider. The Corbin does provide more comfort for long hauls. I mostly make shorter trips so I don't mind.
You will be a little closer to the ground if you use the OEM seat.
