ToThrottlemeister or not to Throttlemeister, that is the ...
marecycling
Post by marecycling »
Is the Throttlemeister the best product available for BMW cruisecontrol? If so, where is the best place to pick one up?
Thank you,
MArecycling
The "good things" that come to those who wait, are just the "leftovers" from those who didn't!
Biff's R
Donating Member #: 289
Post by Biff's R »
bang for the buck, the throttle rocker is better. If you are in a hilly area the throttlemeister/bobs wrist rest will always require constant adjustment.
Jeff (lifer #289)
'17 F800GSA
'04 R1150R
dnat928
Post by dnat928 »
My new (to me - 2002) RR has them - they are GREAT. My old cruiser had a Cramp Buster - I thought that was good...til I got the RR and began using the 'miesters. Once twisted into position, you can relax and cruise with just fingertips on the grips. I occasionally take my RIGHT hand off the grip when another cycle is nearby and do something innocuous, like adjust the mirror, just to see if he notices.
And, um, there's the no-hands thing too, but better not go there... :wink:
Member #1058
BMW R1150R - 2002, Atlanta Blue
Porsche 928 - 1982 Weissach Edition, S/N 34
Beemeridian
Donating Member #: 477
Post by Beemeridian »
2354
2015 Honda PCX150
challey
Donating Member #: 365
Post by challey »
The South African company Kaoko offers a TM-like control that's a bit less expensive
http://www.adventurersworkshop.com/kaok ... ntrols.htm
Not familiar with either unit but both seem to get good reviews.
'03 R1150R
Life member 365
Errabundi Saepe, Semper Certi
big papa
Post by big papa »
I had the TM on my Rockster and Hayabusa, worked as advertised, but rarely used it.
'07 R1200RT
Panzerleder
Post by Panzerleder »
I wouldn't ride without a Throttlemeister. They are great -- much better than Bob's wrist rest which never worked properly. However, for elegant simplicity (not to mention low cost) nothing beats the old drilled set screw that used to come on the old R and K bikes -- before we became such a litigious society.
geothepencil
Post by geothepencil »
The TM with a supplementary ridged ring (for ease of setting on or off) mounted on the inside edge of the weight works very well for me. The ring was custom made by a machinist and sourced through Twin City BMW in Savoy.
geo
Ed K
Post by Ed K »
Definitely go it, IMHO. I have one and its great... would recommend the lighter weight, of the two weight options.
Ed K
07 K1200S
Lifetime Member
HILLBILLIEBIKER
Post by HILLBILLIEBIKER »
Throttlemeister works for me. :D
What could be better than going on 60 yo on a BMW R1150R going on 60 mph? OK lets not get into that
baltm604
Post by baltm604 »
If you are frugal (did I say I'm cheap!), try bob's bmw for a bob's wrist rest. they will sell just one side for less than having to by the matching left side weight from TM.
wncbmw
Post by wncbmw »
I use the el cheapo trick of the rubber gasket between the throttle and the bar end for enough friction to allow taking my hand off when needed. Never liked the throttle rocker and took it off.
Do the TM and Bob's both take a different model for the R vs the GS? If so, I would need two, since I use the GS handguards in the winter.
My 10 cent part is universal! 8)
Amen to that! My old RS had one and it worked perfectly and simply with infinate adjustment.
Vann - Lifer No. 295
baltm604
Post by baltm604 »
I do the same thing. gs handguards in the winter. I ordered the GS version from Bob's and have no problem in the summer.
I just remove the handguard and put the bolt back in the weight.
jm1515
Triple Lifer
Post by jm1515 »
challey wrote:The South African company Kaoko offers a TM-like control that's a bit less expensive
This is what I use...and also purchased at AdvWorkshop.
It's well made and can be easily controlled, even with gloves.
I had to polish the bar end, tho, as it came in a flat black.
j magda
TripleLifer Member 454
Deep in the OH wasteland...
