Question (again) About Givi Topbox Install
All other motorcycle related topics go in here." However, DO NOT post ANY messages that are related to politics or religion in here. They will be erased. Thanks!
LonestaRR
Post by LonestaRR »
I got my bike back today and my neighbor helped me put the Givi on to the mount. Then I took it out to see if it made a difference in handling and noticed a problem with it. The bottom of the mount does not sit flush with the BMW rack and so it is bouncing against the rack as I ride - the exposed bolts are scratching the rack. Is there a fix for this?
The picture shows where the bolts closest to the pillion are scratching the rack.
Kristi
TonyT607
Donating Member #: 156
Post by TonyT607 »
Hey Kristi, sent you a PM.
Tony
Lifetime #156
2013 K1600GT
LonestaRR
Post by LonestaRR »
Thanks Tony - sent you one back.
K
ebiker
Re: Question (again) About Givi Topbox Install
Post by ebiker »
Kristi wrote:I got my bike back today and my neighbor helped me put the Givi on to the mount. Then I took it out to see if it made a difference in handling and noticed a problem with it. The bottom of the mount does not sit flush with the BMW rack and so it is bouncing against the rack as I ride - the exposed bolts are scratching the rack. Is there a fix for this?
Kristi
It doesn't look like you're using the right mount, Kristi. Try the 2002-04 BMW K1200RS soft bag black plate with enclosed lock. It snaps onto the Roadster back rack. I used one with the soft bag and the hard bag. (I just may have one around, somewhere).
Ed..
I'm outta' here!
LonestaRR
Post by LonestaRR »
Ed:
Thanks for your reply. However, that is the mount I'm using. I got it from TonyT607.
K
bimrluvr
Donating Member #: 429
Post by bimrluvr »
Hi Kristi,
When I bought a Givi-knockoff top case, I wound up buying the Givi adapter plate which replaces the BMW rack.
#429 (in for life)
'06 Silver R1200RT
taosports
Post by taosports »
Kristi,
I discovered the same problem. Check out this previous thread for my solution.
http://r1150r.org/board/viewtopic.php?t ... light=givi
ebiker
Post by ebiker »
Kristi wrote:Ed:
Thanks for your reply. However, that is the mount I'm using. I got it from TonyT607. K
Okaaaay! I took a closer look at your picture and a look at the plate I have---yep, you're right----plates are the same. The rear rack for your bike should be the same as on my 2005 R1150R.
So, seems the problem is the hardware attaching the plate to the Givi box. Try using shorter bolts??
Ed..
I'm outta' here!
gregor
Post by gregor »
My Givi has a mounting plate which replaces the BMW rack very neatly.
Does not look so good when top box is off; which is rarely.
rph802
Post by rph802 »
Looks better than mine...
The finished product is a little slicker when the rear seat and bags are on
Definitely prefer the looks of the setup on the 1150
Life is too short to use cheap toilet paper :D
Member #457
95 R1100R Red
gregor
Post by gregor »
My top box is a Kappa, which is interchangeable with Givi AFAIK.
BMW rack was removed so I have 4 empty holes. Long mounting arms then pick up on pannier mounts and a special top box pad is fitted.
Must try a photograph later.
Motorrad
Post by Motorrad »
Can the bolts be mounted in reverse (Bolt-head under the plate and nut above)?
Steve
Yellow-Jacket
