I used the tip on the tech tips page posted by s2pidduncan about adding rubber grommet spacers to the top mountings of my speedster screen to make it a little more upright. It only moves about 5mm nearer vertical but it has made a huge difference to the way the screen works! I could ride at 90+ all day now whereas before I was getting hammered at 80. I didn't even need longer bolts. Great tip!
Speedster screen buffeting
Hi
ferroknight
Challey:
I have the smoked BMW sport screen -- I have added approx. 5/8" of rubber washers to the upper bolt/mounts. This reslulted in the screen moving forward and slightly upward approx. the same -- 5/8".
Being 5'9" tall, this change helps deflect the wind slightly off my face shield, making high speed buffeting a bit less bothersome.
No, I backed off the bottom bolts, removed the uppers and installed a nylon washer through the bolt as a spacer -- This gave me about 3/8", then I re-installed the upper bolts and left them only barely threaded -- pulled the shield forward and slipped in a 1/4'' rubber hose gasket that was split to slide in over the installed bolt (between the nylon washer and the shield).
These 2 washers equalled 5/8" of forward adjustment.
You get enough thread in the well nut to hold tight but, I went ahead and used Locktite just to be sure.
