PIAA 1100x wiring w/ AutoSwitch
dnorrell
Post by dnorrell »
Hey there...
Here's the deal. I am thinking of installing some 1100x driving lights and had a couple of questions for those of that may have already gone down this path:
1) Can I purchased the standard set (part #1192) and be okay with the wiring part of the install?
2) Any difficulties encountered when installing them along with the AutoSwitch product (that allows you to turn them on/off via turn-signal cancel switch)?
http://www.cyclegadgets.com/Products/pr ... sp?Item=AS
I think I am going to install them on the mount points on my Wunderlich crash bars, and the PIAA 1100x driving lights look like a solid option.
Thanks, my friends...
Adam
2004 Silver R1150R
beemerphile
Post by beemerphile »
The instructions that come with the autoswitch are quite adequate. Be sure to get the negative switched model designed for BMW's. - Lee
Dizzy
Same One
Post by Dizzy »
I have these same lights same crash Bar and they were avery easy to install (I am mechanically challenged), I do not have the autoswithch so cant help you there.
Just one more thing be careful on how tight you bolt them to the Eunderlich Bar I almost broke the plastic footing on the lights.
"..in a perfect world we would all be Yankees."
Eqyn Dad
Post by Eqyn Dad »
Along the same lines...
is the Autoswitch and a Kissan Signal Minder compatible?
