Hi, Iv'e searched the topics and can't the answer to the following.
I want to know whats the hottest the oil temp gets to? This is as I want to repaint the cylinder heads, and I'm not sure what temp paint I need.
If anyone has any advice on reoainting the heads, that would be appreciated too. Should I just remove the loose paint, and paint over or does it all need to come off?
Many Thanks
R1150R Oil Temp? / Cylinder Head Painting?
Check your auto store, they should have hi-temp paint designed for engines.
You are supposed to apply it to the engine, let it sit for 24 Hrs then run for at least 1 hour to cook it.
Anyway, the directions are on the can.
I scratched my black engine by laying down the bike the first day I got it 2 years ago. I let lean while waiting on the driveway for the garage door to open. It looked pretty ugly. I painted over the scratches. NO problem since then.
Nobody is sure perfect, but she practiced tirelessly !
Thanks for the info, but its temp I need to know. I dont want to do it with some paint which might flake off again. There are engine paints at 160c, 300c and 650c. I could just go for 650c paint, but I think the paint quality (Appearance and durability) at this tempreture is not as good a finish.
Thats why I thought if anyone new the temp at which the oil runs, I could select the appropriate paint.
I'm pretty sure the normal engine oil temp range is in the owner's manual.
The AMSOIL White Paper looked at viscosity of oils up to 100 degrees C, scarring at temps up to 150 degrees C. and volatility (light components off-gassing) up to 250 degrees C.
http://www.amsoil.com
#429 (in for life)
'06 Silver R1200RT
'04 Titan Silver R50R (3/05-9/10 was a good friend - RIP)
'06 Silver R1200RT
Re: R1150R Oil Temp? / Cylinder Head Painting?
I have a CycleRob-inspired VDO oil temp guage mounted. The hottest I've ever seen is just shy of 280' on a 90'+ day sitting in stop and go traffic....Disney wrote:Hi, Iv'e searched the topics and can't the answer to the following.
Many Thanks
j magda
TripleLifer Member 454
Deep in the OH wasteland...
Oiltemp
This has been posted before and was originally taken from bmwst.com. My apologies to the original author as I don't have his name. The diagram is a schematic of the R1150RT temperature gauge with the corresponding oil temperatures that were tested. The tests were actually done on an R1100RT but the gauges are the same.
