Just had my 12,000 mile service done at the local BMW place.
I really can't remember the "before" but now the bike idles right at 1,000 rpms. This seems low and now I have to give it little gas to keep it running at start-up...but it idles OK when warmed up and runs fine.
I'll check my non-BMW service manual tonight but I wanted others input.
Turn your BBBPSs counterclockwise just a smidgen in equal amounts. Cold starts will be lower but the hi-idle lever compensates until it's warmed up. When its warm it should be at 1100RPMs.
Boxer wrote:Turn your BBBPSs counterclockwise just a smidgen in equal amounts. Cold starts will be lower but the hi-idle lever compensates until it's warmed up. When its warm it should be at 1100RPMs.
Why don't you use the hi idle lever at cold start up as Boxer suggested? Its in front of the clutch reservior. Sounds like its doing what its supposed to do.
soggybottom wrote:Why don't you use the hi idle lever at cold start up as Boxer suggested? Its in front of the clutch reservior. Sounds like its doing what its supposed to do.
