cylinder head guards
- Dr. Strangelove
- Double Lifer
I see that there are at least two different styles of cylinder head guards--one(rectangular) seen on the Sierra BMW site that is described as BMW "OEM" and the other (sort of triangular) that can be seen on the A&S site.
The ones I see most often are the triangular shaped ones, but the others look like they might?? offer superior protection. Both are priced at ~~ $97-98.
Is one better than the other?
TIA
TIA
cyl guards
Single spark vs dual spark is my guess...
If both protectors you see are BMW protectors, what you're probably seeing is the difference between protectors for single spark engines (square) and protectors for the 2004+ twin-spark engines (slanted).
I can confirm that the slanted protecors do not fit single spark engines...I tried. Can't confirm it but I suspect the reverse to be true...square not fitting twin-spark.
I was at Carolina BMW one day and Jason let me hold one up to my bike. One or more of the holes just didn't line up, and they didn't fit the more rounded outline of the single spark valve cover.
DSKYZD
Edit: Awww Rich, you beat me!
DSKYZD
JOURNEY JUNKIE #187
- Dr. Strangelove
- Double Lifer
- Dr. Strangelove
- Double Lifer
- Dr. Strangelove
- Double Lifer
Head Guards
I had not heard of the OEM Nylon head guards breaking as the Stanton link suggests. Maybe running down trails and through underbrush on a GS. But on a R1150R isn't the "protection" mostly a skidplate function for the odd drop or low speed front tire wash out on gravel, etc? Anyone break an OEM guard just dropping the bike or due to a slow speed spill?
- Dr. Strangelove
- Double Lifer
Yes, that's why I asked the question. I was out at the lakefront here in NO last Sat and it was very windy. I was stopped, perpendicular to the wind and a gust tipped me and the bike over. The bike went down in slow motion (at 0mph) to the left, rolling on the left cylinder. The lower arm of the guard was split longitudinally, though still holding together.
beemer-biker
Dr. Strangelove, how is the lakefront at this time? I am a born and bread N'Awleanian, moved up the WA area about 2 years ago. By this time, I mean since Katrina, not the time of the year.Dr. Strangelove wrote:Yes, that's why I asked the question. I was out at the lakefront here in NO last Sat and it was very windy. I was stopped, perpendicular to the wind and a gust tipped me and the bike over. The bike went down in slow motion (at 0mph) to the left, rolling on the left cylinder. The lower arm of the guard was split longitudinally, though still holding together.
What area do you live in? Was it hard hit?
beemer-biker
Ride safe!!
'06 Aprilia Caponord
Ride safe!!
cylinder heads are cheaper
No need for guards. They cost you more than cylinder heads. You will save money just replacing cylinder heads if and when they get scratched beyond your tolerance.
still a good idea
I disagree with just buying new valve covers when they get scratched as a reason to not buy valve cover guards. If your 100 miles from home, and drop the bike, and put a hole in a valve cover, your stuck, even if the bike is still in rideable condition. You can't ride the bike with oil running out of the valve cover, and for the price of the tow, you could have bought those valve cover guards. Buying the guards as a way to keep scrathes off the valve covers isn't the reason to buy them, keeping on the road, and riding after a spill could be, unless you don't mind waiting a few hours for a tow to arrive. I would rather ride home.
Don
Don
Re: Head Guards
I've seen other riders experience road accidents where the OE guards haven;'t protected the valve covers. Not experienced the problem myself because I've had Stantons.zooomart wrote:I had not heard of the OEM Nylon head guards breaking as the Stanton link suggests. Maybe running down trails and through underbrush on a GS. But on a R1150R isn't the "protection" mostly a skidplate function for the odd drop or low speed front tire wash out on gravel, etc? Anyone break an OEM guard just dropping the bike or due to a slow speed spill?
the OE guards don't protect the upper half of the valve cover at all - the Stantons do, and well.
relativey easy if you're mechanically inclined.mnnden wrote:I am thinking of getting the Stantons, can anyone tell me how hard a job it is to install them, Thanks, Denriceburner wrote:What the man said... Stantons rock.
Not sure if they do a correct twin-spark version yet though - but the single spark version fits, you just have to trim the secondary spark plug's weather cover a bit, its obvious when you look. I have a couple of pics on my website - http://www.riceburner.co.uk
