http://ridesafer.com/store/item/qrqu/Co ... Light.html
I would like to get this but not sure which would work with the K12R. I am thinking it needs to be the Blake Box Wire In Type.
Does anyone know?
Has any one had any experence with this one?
Marty
3rd Break light
martydallas
Below is a note I sent the seller. Don't get the LED tail light transmitter 1157 bulb it will give you an tail light error. Get the Black Box transmitter. The LED Bulb transmitter does not draw power, the bike thinks a bulb is burned out.
Well just got it all working and it is great, had our annual
motorcycle meeting setting our group calendar for the years ride, Showed the
light off, everyone thought it was cool.
just as a note on BMW with ABS breaks and bike equipped with "Bulb
failure detection" should only use the module. To wire it up the RED
wire should go to the Bikes "black/gray/yellow" wire and the BLACK wire
goes to the Bikes "brown" wire. Feeding the tail light bulb.
Hope this helps.
Marty
Hope this helps.
Marty
