excess oil consumption
hybridmoose
Post by hybridmoose »
Guys,
My Roc only has 15K km on the clock but seems to be using an excessive amount of oil. The manual says that it is within spec if it burns up to 1litre per 1000km, which is about what my bike is burning. This seems way excessive to me, especially coming from a yamaha which burnt maybe 150ml between services. What are your thoughts?
leno
Post by leno »
They all do that. Sorry but it's not a sushi bike and they do burn oil. If you are lucky it may get less as it ages but you will hear conflicting advice on how to get to that state.
Yahoo-Boy
Post by Yahoo-Boy »
Mine actually burns a little more than average, but the shop has been through it multiple times and that is just how mine consumes oil. I know it seems crazy (I came from a Suzuki) but that is how it is. Just remember to keep an eye on it. It's easy for me to forget to top it off regularly.
~Scott
"If you can't say anything nice, at least have the decency to be vague."
cammy
Post by cammy »
8) Only 6300 mls on the Rock at the mo, using about a litre of Castrol GP mineral per 1000 mls.
CARNAC MOTO, 2001, 2003, 2004, 2005, 2006....2007?
Dred80
oil consumption
Post by Dred80 »
Mine isn't quite as high as the upper limit of "normal" but it does burn it. I'm told that parking it on the side stand is part of the problem but that's not the whole deal. Mine will burn down to the middle dot then stay there for two or three thousand miles then it will burn half a quart in 1000 or so miles. I just keep some on hand and always take a quart with me on long trips. My old K-bike does the same thing and it's got over 100,000 miles on it.
B.Dred
fnfalman
Post by fnfalman »
Mine burned oil exactly as the manual said for the first 1000-miles. Nowadays, it burns a bit less, but it still burns.
Donating Member #: 312
Post by boxermania »
One more time.....this has been addressed several times before on the old site.
Oil level at the center of the bullseye, no more, measured on the center stand.....be carefull, sometimes weather conditopns are such the the oil cooler thermostat will not open, trapping oil in the system, the result is that upon looking at the bullseye it would appear that the engine needs oil........wrong, as you will notice the next time when the level is way past the bullseye. In any event, I woulkd not run the bike if the oil level is not seen on the window.
alusil or nicosil as the cylinder coating - hard, long wearing
Rings seat against the cylinder wall which is hard to begin with......
Solution:
Run the bike hard, tach it throught the gears. These bikes are made to run. Running hard means up and down, not WOT for hours on end.
If done in the above fashion the bike will cease major oil consumption around 6K miles, if you are burning oil at 20K miles you have babied the bike and it will take a long time to seat the rings or there is something wrong with the engine. :roll:
Dred80
babied bike
Post by Dred80 »
Yeah, this issue has been addressed everywhere, including here and everyone has a different opinion. Fill the oil to here, don't fill it at this point, pay attention to the manual, ignore the manual, shade tree guy knows more than trained mechanic. ect. ect. ad nauseum....
I've never babied this bike, I've run the crap out of it in fact, and at almost 36,000 miles, it still burns about a quart of oil between oil changes.
B.Dred
Leno
Re: oil consumption
Post by Leno »
Dred80 wrote:Mine isn't quite as high as the upper limit of "normal" but it does burn it. I'm told that parking it on the side stand is part of the problem but that's not the whole deal. Mine will burn down to the middle dot then stay there for two or three thousand miles then it will burn half a quart in 1000 or so miles. I just keep some on hand and always take a quart with me on long trips. My old K-bike does the same thing and it's got over 100,000 miles on it.
If you fill past the dot then it will burn more because it is over filled. But then if you don't it will be under filled quickly.
Dred80
Re: oil consumption
Post by Dred80 »
Leno wrote:If you fill past the dot then it will burn more because it is over filled. But then if you don't it will be under filled quickly.
Once again, this opinion differs from so many others that I'm skeptical of all. BMW manuals say fill it to the top of the circle, Leno says not, but every dealer I've ever had service my BMW's fills it to the top. This debate is endless and will never be resolved.
B.Dred
Re: babied bike
Dred80 wrote:Yeah, this issue has been addressed everywhere, including here and everyone has a different opinion. Fill the oil to here, don't fill it at this point, pay attention to the manual, ignore the manual, shade tree guy knows more than trained mechanic. ect. ect. ad nauseum....
ditto.
Rockster_Cyp
my comments
Post by Rockster_Cyp »
I had this question too..
My bike has 10000 km and burns 0,5 Litre between the oil changes ( i do this every 3000 km)
Untill now I was usind mineral castrol oil but now i will be changin to PJ1 semi synthetic oil.
A friend of mine with R1150R has around 32000 km on his bike and he recently changed to full synthetic PJ1 and has found it excellent.
No extra oil is needed now, the gears are smoother and also he feels the bike that works more calmly.
Who knows...
I will try it too and tell you my comments too. I will be using the semi synthetic for up to 30000 km and then change to full synthetic.
Lets Rock..
hybridmoose
excess oil
Thanks guy,
The Roc is booked into the dealer on Monday to have a look at the excess oil and carry out warranty work on the fuel lines.
I have heard that a change to fully synthetic oil will reduce the oil consumption, but it was suggested to wait until 20K km. It might be worth a try to see if it reduces the consumption.
whip
oil consumption
Post by whip »
I have just returned from a 4000 mile trip from California to Memphis and back and my rockster ('04 with 20,000 miles) used less than 1/4 of a quart. Runnig the interstate at 80+ for 14 hours comming back to California in very hot conditions in places.
I run it hard and the plugs are clean with no carbon to speak of. Use dino oil no additives. Almost as good as a Honda
Cheers All
DJ Downunder
Post by DJ Downunder »
I changed to fully synthetic after only 1000 klms (600miles)...it's now almost 4yrs and 40,000klms with no probs.
hybridmoose
oil consumption
Guys,
Roc is back in the shop after my trip for the 20000K service and to have "a deeper look" at the oil consumption. I will keep you informed of the progress. No news yet. They have had the bike for 3 days so far.
captainK
Oil consumption
Post by captainK »
It has to be said that BMW are hardly shy about telling owners that their bikes will consume oil ... there are numerous warnings in the owner's manual, my bike has a decal on the gas cap as a reminder to regularly check the oil level, and when I was taking delivery of the bike the dealer explicitly mentioned the need to check the oil.
I figure it's just something you learn to live with -- and while most newer vehicles don't burn much oil these days, they certainly did when I first started riding. I will be interested to hear the reports on whether the switch to mineral oil makes a difference though ...
R4R&R
Donating Member #: 293
Post by R4R&R »
I had an air cooled Yamaha that burned oil. I had a water cooled Suzuki that didn't seem to burn a drop between oil changes. I have an air cooled BMW that burns oil. I think I see a pattern.
Mine is within spec, but I do need to keep an eye on it.
Member 293 (I think)
'17 Triumph Tiger 1200 XRX
Yes...I see a pattern too...
1st one - yes, 2nd one - no, 3rd one - yes......
