Starter motor whine
garfieldus
Re: Starter motor whine
Post by garfieldus »
garfieldus wrote: ↑Sat Apr 17, 2021 10:04 am Fitted it, went to start the bike and although it turned over strongly, the bike wouldn't start!!!
kirby wrote: ↑Sun Apr 18, 2021 11:15 am You did check the stop/run switch was in the run position?
On my bike, it won't crank unless the stop/run is in the run position. Is it not the same on all 1150r?
kirby wrote: ↑Sun Apr 18, 2021 11:15 am Are you sure you have the right starter? part # check?
As it's a spurious part there's no part number on it. However, the advert I bought from did specifically mention my bike model.
kirby
Donating Member #: 3
Post by kirby »
I think your right the stop run switch kills the starter as well.
It sounded like maybe a blown fuse. If that starter is working it has to be something like a cpu fuse, Seems almost certain to be related to the starter??
New one for me.. Will be interesting to fine out.
I will keep thinking but never had that one happen in 20 years of oil heads and may miles.
mike Mojave CA
'04 ROCKSTER
