Charging a gelcell battery on R1150R
Jay360
Post by Jay360 »
Any information on fast charging gelcell battery on 2004 R1150R? I have a battery tender charger, but I would like to start the motorcycle as soon as possible.
bakernks
battery 2004
Post by bakernks »
Iffy to fast charge that gel cell, IMHO. Why not jump start the bike using the new for 2004 starting studs supplied by BMW, and take a ride, just don't shut off for a half hour or so? The positive stud has the rubber cap marked positive, it's on the starter cover, the negative pole is near the left cylinder cam cover. BE SURE you have the polarity correct...
2 spark BMW's: '04 R1150R, '05 F650GS
Acacia
Post by Acacia »
Jay,
there were several posts on the old board. The standard Battery Tender is not suitable for charging the BMW gel cell. Battery Tender make a Special Charger for the gel cell - it is marked as such. I now hasve both Tenders as I had 00 R before my 04.
The BT is considerably cheaper than the BMW version for the gel cell.
Why is your battery dead in the 1st place? If there is some residual charge ( under 11.5 volts), but not enought to start - jump it or push start it. If the charge is way down - you need to find out why.
If just below power to start - take Bakernks advice
Member #192
"Life is a curve!"
Jay360
Re: battery 2004
Post by Jay360 »
Starting studs supplied by BMW??? I have never heard of this. What is exactly is this product.
Jay360
Post by Jay360 »
The battery went dead after I left the key on when I was at my brothers house for four hours.
Biff's R
Donating Member #: 289
Post by Biff's R »
If you have a 2004, then there are two studs to hook onto and you can jump start the bike. I would think that everything would be okay, if you jumped the bike, or push started it, and then took a long ride.
I don't think that you would completely drain the battery in 4 hours, but I could be wrong.
Jeff (lifer #289)
'17 F800GSA
'04 R1150R
Badger
Post by Badger »
Hmmm.....I have used my battery tender junior to recharge the battery in my 04 r1150r with no problems.......tho the folks at battery tender were unable to tell me if it was okay or not....they said they didn't know. ..in any event bike sat for about 8 weeks in an unheated garage and it was COLD.....battery needed a charge.....I had the battery tender junior......just plugged her in and let it recharge ...........
madbinkster
Post by madbinkster »
acacia....I was under the impression that you shouldn't (or couldn't) push start our bikes..
no fuel pressure when battery is dead. clarification would be helpful.
"Pull over Mike....we need to wait for the Harleys...they've got the food."
Guest
Studs?
Post by Guest »
I've got an '04. The studs sure are not "jumpin"" (pun intended) out at me. Anybody got a picture. Or could this have been a late '04 change?
priapismic
Studs?
Post by priapismic »
I think that was a "late" '04 model change. My "early" '04 was bought in March of '03, one of the first of the twin spark '04's, and I have no such charging studs on my bike. I have found, however, that I can charge my battery (with a trickle charger) by using my electric vest connection, I just connect the alligator clamps to the e-vest connector terminals.
Acacia
Post by Acacia »
You can jump start an R if there is enough residual battery to run the fuel pump and pressure the fuel injection, but not enough to turn the starter over.
Charge buttons on the newer R's - negative on the left head and positive on the side of the starter motor cover - cant miss them if your ride is fitted with them. Otherwise remove the seat and connect to the battery itself.
Cant remember the detail, but there is something in the construction of the BMW Cell that does not like the regular charge to sustaing charge cycle profiles of a standard charger. It probably will get you out of a bind, but is not recomended - particuarly if left on for extended periods.
Member #192
"Life is a curve!"
Biff
Post by Biff »
My understanding on the Battery Tenders is that there is a difference in the rate of charge, and the charging cycle between the gel tender and the lead/acid/AGM tender. It is a programming thing in the Tenders. I would think that 1 charge would not do damage, but continual use of the "wrong" Tender may have some negative effects.
fnfalman
Post by fnfalman »
http://www.roadgear.com makes a couple of battery tenders that supposedly rated for gel batteries AND come with the plug for BMW power plugs. At $49, it's not significantly cheaper than the BMW one, but it seems to be very small and light, not to mention there's a waterproof model.
Battery Advice Guy
Tenders
Post by Battery Advice Guy »
Battery Tender brand for Gel + BMW gel battery = good
Battery Tender Junior (old style) + BMW gel battery = okay (charge cycle is two stage and peak charge is sufficient for gel battery chemistry)
Battery Tender Plus (mid 2004 and earlier) + BMW gel battery = poor (will charge but will also damage battery chemistry - not fatal but serious)
tipstall
Donating Member #: 487
Newbie Batttery Question
Post by tipstall »
Being new to not having a kickstarter I have a question. Do most people use a battery tender? When I picked the bike up I was told the BMW computer is on when the bike is off and will drain the battery. Is this true? How long will the battery last and still be able to start the bike?
Below is the BMW battery tender. Is there a good place to order this online as I don't have a shop close?
Battery Tender Generation II Part number: 99990005656
Silver '04 R1150R
#487
Acacia
Post by Acacia »
The clock is also running.
Cant answer the other electrical drain questions - but several weeks or more should be fine with a battery in good condition - also temp affects cranking capacity.
How long and where are you going to store it/not use the bike for?
I got my 'tender' for the gel directly from them - they were cheapest at the time - also call them
Member #192
"Life is a curve!"
Kevin50r
Stud Location
Post by Kevin50r »
I have a 2002 and if I turn the handle bars just right I can see a "stud" in the mirrors. :lol: I checked the manual and the 2002 doesn't have this feature but every time I look there he is?
Member #363
2005 DL-650
2013 XT-1200Z
Kevin
Guest
Post by Guest »
I have an earlier '04 without the jump starting studs. Has anyone retrofitted this feature to a bike that didn't come with it? If so, how much were the parts?
Thanks,
--Phil
2004 R1150R Titan Silver
vintagecycle
Post by vintagecycle »
This topic has come up before. I remember reading that the altenator on the bikes did not change when the they started using gel cells. So, how would the altenator know the difference in charging cycles?
I have used my standard BT on my gel cell with no problems.
Dan
'04 R1150R (Silver) Sold
'85 Yamaha RZ350
'81 Yamaha YZ125
dallara
I use...
Post by dallara »
I use one of these little gems to keep the Odyssey PC680 battery in my Beemer charged up:
http://www.batterymart.com/battery.mv?p=VDC-12112
Rigged up a powerlet plug adapter and simply plug it in the Beemer accessory socket. Never had a problem. I stick it on overnight about once a week if I'm not riding the bike.
Now, my understanding is that you want to "fast charge" gel cells of the size in the Beemers at about 6 amps or so. Still would take a bit of time to get one charged if it is fully drained...
Cheers!
Dallara
