AllanB
leno, pretty much covered all the issues. You might want to keep an eye on it....a little weeping is not a major consequence.
Regarding replacement shocks there are several choices:
1) OEM, I haven't priced them but hear they are in the $600 to $700 range
2) Brunos in Canada will rebuild your OEM set and tey will be rebuildable thereafter, cost $ 400 for both. I haven't used their service but Patrick (contributor to this site) has and you should ask him.
3) Works Performance and I think Progressive also make good, rebuildable shocks and they are slightly more expensive than the OEM.
4) Then you have the high end shocks, Ohlins, Penske, etc, certainly excellent shocks but their cost $1400 to $1500 is not justified.
BTW, whatever you decide, do both front and rear to keep the balance of the bike.
If you presently do the maintenance on your bike the shock swap out is not a big deal you do have to pay attention when the suspension is unloaded via the removal of the shocks.
Good luck and let us know how you make out............
