I seek the collective wisdom. The rear end of the bike (R1150r) is making a little clunk- big clunk sound they:
1 - Only happen after the bike is warmed up, and
2 - Are separated by approximately ninety degrees of wheel rotation (picture below, skinny strip = little clunk, fat strip = big clunk
3 - Only happen once (little clunk and big clunk as a set) per rotation.
4 - Can be felt through the rear brake when the bike is warm and coasting in neutral down a steep hill. (Underground car park drive way)
As you can see I have a non standard rear wheel. It is an R1150 GS hub mated to a 17" spoked hub. To ensure the correct offset it uses the large 4 hole spacing washer (R1150 GS part # 36317653286) between the wheel and the final drive. This is the same part as used in the Rockster (5.5" rear wheel) to achieve the right offset.
I did not notice the clunking until recently and the wheel has been in place for about six weeks.
Theory one - Could be the rear universal joint on the final drive shaft. This part was replaced about 60,000km ago but I could only afford a good used part not a new one. My feeble brain is trying to work out though how many times the shaft rotates for each wheel rotation when the bike is in neutral. A ratio of 1=1 doesn't make sense. if it was this part it seems it should not clunk once for each wheel rotation.
Theory two - Could it be something to do with the re-attachment of the rear disk rotor. The rotor bolts that match the GS hub are 5mm shorter that the standard R1150r rotor bolts. I only realised this out when the wheel was off and at the shop. I couldn't get the correct part so my bush mechanic solution was to shorten the existing rotor bolts on a bench grinder. As the disk gets warmer might some misalignment cause the sound? Not sure, I would have thought it would just have rubbed or touched against the pad. The sound is an audible soft/loud clunk sound. I suppose the simplest test for this theory is the removal of the wheel and the replacement of the rotor bolts with five factory bolts.
I haven't removed the wheel again yet... Before I do so I would like to have at least some theories about what may be causing it.
I don't want something to lock up at speed and hurl me to my doom or mess up something expensive in the final drive area.
Any suggestions are much appreciated.
Sol
