Brightest bulbs for stock assembly
MThomas
Post by MThomas »
I was at the parts dept at the non-brand specific cycle store the other day and figured I'd get headlight and tail light bulbs.
The guy didn't know what the stock setup was and couldn't recommend a bulb.
Anyone know:
a) the brightest bulb you can buy to fit in the stock assembly and
b) an online source to obtain these?
2004 R1150r Non-ABS
Sunbeemer
Donating Member #: 593
Re: Brightest bulbs for stock assembly
Post by Sunbeemer »
I'm using Philips X-treme Vison +100% in the headlight which they claim delivers double the brightness of a stock 55W halogen bulb even though it uses 55W. Really it seems like it's 75% brighter than stock, and a significant improvement.
There are halogen bulbs available for "off-road use only" that are brighter and draw more current (100W), which the wiring to the headlamp can't handle without adding a separate relay.
In town during the day I burn the high beam for increased conspicuity, and it does makes a difference in how well cagers see me.
ADIOS!
I run high beam consistently during the day. I also run a set of LED running lights that I bought off of eBay similar to these. Mine are 5" with a 30 degree beam, are considered 27 watt lamps. A pair makes my headlamp look like a candle. I don't run them at night, just daytime so people don't pull in front of me. And they work!! They are not DOT legal in Va so I pull them for state inspection and re-attach after.
I paid about $25 shipped for the pair. The choices available are near endless. I've been running them for 3+ years now with zero failures.
http://www.ebay.com/itm/2x9-LED-12V-Car ... NV&vxp=mtr
MThomas
Post by MThomas »
Those look like what I want but where did you place them and how did you connect them?
2004 R1150r Non-ABS
My brackets were given to me by a friend. They may have originally come from a company called Clearwater Lights.https://clearwaterlights.com/
The lights are connected to an underseat fuse box and controlled by a simple toggle switch attached to the bars. This is not an ideal solution as the switch is not totally weatherproof. I have a device called an Autoswitch yet to install to control switching of the lights by way of the existing turn signal cancel switch. I have them on a weatherproof power cable that I can unplug when I take the bike in for state inspection. I have to remove the lights and reinstall afterwards.
[img][IMG]http://i1048.photobucket.com/albums/s364/WayneBowyer/IMG_08481_zpsc3lptipp.jpg[/img][/img]
[img][IMG]http://i1048.photobucket.com/albums/s364/WayneBowyer/IMG_08491_zps0anlpd7n.jpg[/img][/img]
