I currently have my tank off, and thought to inspect anything else I should replace/repair while it's off. I'm seeing that a couple of the blind rivet bolts around the tank are a bit worse for wear (see attached image). I'm looking at replacing them, but can't quite figure whether the part comes with the washer or not. it's not stated in the microfiche, but those washers don't look like they are listed separately, either. Does anyone know for certain? I was hoping to place an order before the end of the holiday weekend. Otherwise, I'll just call them up and order next week…
I'm looking at https://www.ascycles.com/2/MicroList?id ... l%20Supply part 10 (46632347012)
and there are two more on each side, I'm not actually finding a reference for. They sit at the back (rider side) of the tank (you can see on at the very right of the image below. The second on that side it around the bend…
Dave
Dave
