The story didn't quite end there...
Some things i learned.. Should already know really lol... Triple CheCk THEN freak out. Not vice versa, like I did.
2nd.. Even if you're excited to see it work, do not forget to attach fuel line before turning the key. Splash! Lol
Also, I broke the 2nd plastic QD with the 100times I messed with the tank. O rings ate it.replaced, but I had gas on the cat after a short ride... And couldn't tell if it was new or from the original splash... But I was just over it, and had connector in the box. It's Done.
And, headlight lost low beam, but that's easy.(or I hope it is the bulb lol)
As big a hassle as That was, It feels good to know the bike as well as I do after all that...
