Testing the battery
Testing the battery
Is there a way to easily test the battery voltage with a multimeter without removing the tank?
2003 R1150R
1991 Honda Nighthawk CB250 !!
AZBMWRIDER
Re: Testing the battery
If you have the accessory outlet on the cover over the starter, you could try there, if you have an outlet that plugs into it .
You could remove a fuse and test it that way as well .
'02 R1150R, Atlanta Blue
Thanks. I managed to figure that out while staring at the battery out in the garage. Seems like my powerlet adapter has a short in it or something. I had to move the wire around to get a reading. Would explain why the battery tender was not charging the battery I think.
2003 R1150R
