Compatible foot pegs
racurley
Donating Member #: 1147
Post by racurley »
Is there another bike that has compatible foot peg attachments with the R1150R? The part with the pin that attaches the peg to the bike.
2003 R1150R
1991 Honda Nighthawk CB250 !!
P_Jensen
Donating Member #: 1130
Re: Compatible foot pegs
Post by P_Jensen »
Are you asking about the piece that the footpeg mounts to and is mounted to the subframe? If so the GS ones have the same bolt pattern and will move the pegs forward and down, there have been some previous threads on that.
P Jensen
14 R1200R
Montego Blue
NW VT USA
racurley
Post by racurley »
No. I'm wanting to use the existing plate on the bike. The peg itself fits into the plate. Just wondering if any other pegs will fit. Many of the adjustable pegs I've seen fit the newer bikes. The MFW Vario footpegs have a piece that it made to fit your bike and then the two other parts (displacement arm and footpeg) are essentially universal. Just wondering if the R1150R has a mount common with any other bike.
2003 R1150R
P_Jensen
Post by P_Jensen »
The mounting is the same size as several european bikes, pegs from a BMW F650CS and Triumph Speed Triple (05-08) will fit. There are no inexpensive fixes, most of pegs from other bikes are not going to change the position by much. If you are looking for lower pegs then consider this:
http://www.twistedthrottle.com/sw-motec ... iple-1050i
Good luck.
P Jensen
14 R1200R
Montego Blue
NW VT USA
racurley
Post by racurley »
So, how about one of these super-duper Hong Kong specials? I wonder if they are actually any good. Would be unfortunate if your foot peg broke off while riding down the road.
http://www.ebay.com/itm/Fit-Speed-Tripl ... 1545422299
http://www.ebay.com/itm/Black-CNC-Adjus ... 8a&vxp=mtr
http://www.ebay.com/itm/TRC-Adjust-39mm ... b2&vxp=mtr
2003 R1150R
