Valve Clearance
Riverside
Valve Clearance
Post by Riverside »
Ok... so I am ready to adjust my valve and I have a Clymer manual and it say the clearance is .005 to .040. This seems like a wide tolerance to me. Is this correct? I last did a valve clearance on a Triumph and memory tells me it was much closer. I thought it would be closer with a German machine. Any input?
Bob
2004 R1150R - Mad Maxine
Nuevo Arenal, Costa Rica
Buckster
Donating Member #: 543
Re: Valve Clearance
Post by Buckster »
Should be .015 on the intake and .030 on the exhaust. And make sure you do all 4 valves at once.
Buckster '03R
#543
Riverside
Re: Valve Clearance
Post by Riverside »
Thanks Buckster. I'll be doing the job this morning. And, looking at the manual again I just now realized that I was reading the clearance for the rocker arm end float and not the valve clearance which is very clearly listed on the facing page. #-o Glad I needed to get a plug cap removal tool before doing the job yesterday. Need to slow down and smell the Castrol.
Bob
sstein
Donating Member #: 25
Re: Valve Clearance
Post by sstein »
On the same topic, can someone explain to a relative newbie the pros and cons of adjusting the valve clearances on the loose side vs the tight side. Is there a noticeable difference in performance? Throttle response? Gas mileage?
2002 R1150R
- my brother-in-law's brother
Buckster
Re: Valve Clearance
Post by Buckster »
I would say to do it exactly how it's called for. You want to have some drag but not too much. I suggest you balance the throttle bodies after the valves are done to spec and you will be rewarded with a crisper throttle response and my bike pulls a lot stronger up to redline. This is the best my bike has ever run. I finally did it myself after 8 years of ownership!
Buckster '03R
#543
sstein
Re: Valve Clearance
Post by sstein »
Thanks Buckster. I adjusted my valves and did TB sync about 2k miles ago (2002 R currently 21K miles). I did as you described, some drag but not too much. I guess I was asking about the difference in bike performance based on the tightness of valve clearances. I doubt I have the skill to really wrench that skillfully, more of an informational question.
2002 R1150R
Re: Valve Clearance
Just make sure you do it cold. ;)
jfortenbery
Re: Valve Clearance
Post by jfortenbery »
You stated, "Ok... so I am ready to adjust my valve and I have a Clymer manual and it say the clearance is .005 to .040."
Looks like either a misprint OR they're mixing SAE and metric measurements.
FWIW,
Jeff
