I noticed some "weeping" on the stock front brake line on my '02 r1150r. I understand this is a common problem and would like to replace it with stainless. Where's the best place to get the new line? I checked "BeemerBoneyard" but didn't see anything. I assume I'll also need the brake bleed tool/funnel as mine is servo assisted abs.
Thanks'
Simon
Where to get Braided Brake lines
AZBMWRIDER
Re: Where to get Braided Brake lines
I've replaced all the lines on my bikes with kits from Speigler performance .
http://spieglerusa.com/brakes/cycle-bra ... -kits.html
I have not had any issues with them .
They have a unique feature, you can turn the banjo fittings so the brake line isn't twisted after you get the fittings installed .
'02 R1150R, Atlanta Blue
