Developed a high whining noise a while back and after a quick post here and responses I believed the problem was my alternator belt.
See post:
http://www.r1150r.net/board/viewtopic.php?f=20&t=25160
Anyway, after a quick research about how to access the belt I removed the cover and immediately knew that the noise wasn't coming from the belt at all but more like inside the petrol tank itself
Another quick search here reveals the problem could be the fuel pump and as I said in my original post, the noise did start immediately after nearly running out of petrol.
Some have said that I can check if it's the pump by swopping relays? How?
Also that it could be the filter - how do I remove this?
If it is the pump I know that the tank has to be removed for access (is it actually inside The tank?) but can I do anything to the pump once I access it to stop it whining or is the pump now knackered?
Any help would be really, really appreciated
Thanks.......
