rt clutch
rt clutch
where to start ..lost clutch pressure in the middle of a 1500 mile tour of western colo.made it to a shop and had system bled worked great for 100ft then the slave puked on the ground, thank god for friends with trailers..anyway replaced slave and fluid now clutch is slipping ,removed starter, clutch disk seems contamination free,but now clutch engages at the top of the lever...any ideas
2003 1150RT
Re: rt clutch
just talked to parts and service tech said air in line could be causing problem... any advice?
2003 1150RT
- CycleRob
Re: rt clutch
This explains it all in detail:
http://r1150r.org/board/viewtopic.php?p=52930#p52930
Continue to scroll down and read at that site to read for more solutions
