UPDATE! New Akrapovic for the 2011 R1200R now installed
I didn't mind the tone of the standard can. Also it wasn't too bad looking, albeit quite round and fat. I got used to it. BUT place it in a direct comparison with the new Akrapovic and well, this new can is sweet music to my ears! Not cheap but really how many farkles are?
Easy install - Much lighter in weight than the original can. The colour compliments the bike well - Did I tell you how sweet those bassy burbling tones are?
Heat shielded Akrapovic sticker had to go as it was too large with several colours, therefore not as subtle as I would of liked. Peeled off sticker and soaked remaining gum with WD40. Then gently wiped off gum with a soft cloth. Manufacturers instructions call for the can to be cleaned with WD40.This works well.
I am not sure why they needed to etch all of those euro standard numbers on the end of the can. Why not underneath or on the back?
Notice the Mudsling farkle?
Hold you breath when stopped with the wind blowing the exhaust back towards you. The can gives off a strong odour which I am sure will disappear in time.
