Clutch starting feeling spongy.. (approx 100) miles clutch was just to the point where it was only activating when it was about 1/4 of an inch from the handlebar.
We went to the Stub and had lunch.. I came out and pulled the cover off the fluid resivoir, it was all muddy looking. Since I figured I had limited clutch usage, we headed to the super slab... four shifts and we were down the road in 5th.. cruising along... then time to make an intersection... NO CLUTCH... completely gone
So.. wondering if this is the dreaded slave cylinder that I should have replaced last winter?..
I just changed out the clutch fluid three weeks ago. When I had spongyness issues then and the fluid was muddy also. So.. I bled the system, cleaned out the resivoir.. everything was good.. I just figured I waited too long to change the fluid.. but now, with just some office commutes and another longish ride.. I've got slave cylinder seal issues?
So do I have to overhaul the master cylinder as well with replacement of the slave cylinder? Am I just assuming it's a slave cylinder seal problem?
Either way, I guess I'm out for a while until I can get it fixed.
Anybody with any ideas?.. confirmation??? steer me right?
Thanks everyone.
