Just for the record, scratch what I said. It turns out my old tire gauge was off and showed the pressure too high, hence the observation that over-inflating was a good thing. With a new digital gauge I find that 32/36 feels just right.hjsbmw wrote:I'd like to emphasize and confirm what daveyator said. My new front tire started developing an uneven wear pattern somewhere around 2k miles: difference between left and right and somewhat bumpy surface, both visible and noticeable by touch.daveyator wrote:My front had scalloped after 13k or so and the rear had a minor flat wear in the center. I usually keep factory recommended pressure but the mechanic told me to simply run 35ish in the front and 40 in rear (in other words the pressure was too low). I put 500 more on the front before I could get it in and the scalloping seemed to have ebbed a little and the bike did feel better with slightly higher pressure.
I started inflating the tires with an additional 2psi, that is, 34psi on the front and 38psi on the rear versus the respective factory recommended 32/36psi. The wear pattern practically vanished, and the tire looks and feels almost smooth again. I have 3.5k miles on the front tire now.
Some tire talk - tire changers and tire wear
Re: Some tire talk - tire changers and tire wear
Harald
2007 BMW R1200R
2007 BMW R1200R
