Coldest Temperature you've ridden you motorcycle in?
Re: Coldest Temperature you've ridden you motorcycle in?
Post by deilenberger »
Passing along a hint for cold-weather riding. The cheapest and most effective thing I've got - a silk balaclava. Cost was $5.00.
It makes an amazing difference since it can be pulled fully down my neck and into my 'stitch. You end up with no cold points on your face/neck. That and heated gear, and a home-made heated seat pad, plus Wunderlich's hand-muffs make for a really comfy ride (I hate cold!).. The only part of me that still gets a bit cold is my feet. I'm giving thought to boot inserts (I have heated socks, but the harness is a PITA, and the are somewhat lumpy with spotty heat distribution - the newest Gerbing may have fixed that with the Microwire stuff..)
Hmmm...
Would be a fix for the days when I don't feel like waiting for the ice to melt in my driveway..
This might also work:
gezerbike
Donating Member #: 775
Post by gezerbike »
Some of the tricks I learned in our 6 years of stupid cold weather trips
When you shower in the morning, give yourself a light coating of Baby Oil or similar product. That thin layer of oil will keep your skin moist. It will also trap heat your body generates. Swimmers of the English Channel used to cover themselves in grease for much the same effect
Thin, windproof/waterproof leather gloves. Heavey insulated gloves will also insulate any heat generated from your heated grips. I'd wear a pair of silk liners under my leather gloves. with an square chemical heat pad on the backside of my hand, between the liner and my glove. This sandwiched my had between 2 heated objects...plenty of warmth and alot better feel for the bars and grips. CAUTION: don't put the chemical pad against youtr skin.
Long sleeve cotton or wool shirt covered by your heated clothing. The heated clothing has to be tight to your body to work, and any thing heavier under it makes it hard for that heat to get to your body. Can't say enough about having gear with a heated neck. This was topped off with my First Gear Baron jacket. 11 pounds of dead cow does wonders for keeping the wind off you
For pants, I'd wear long john nylon riding pants, covered by heavy duty polyproplrene long underwear. First gear Paris Dakar leather pants keeps the wind out.
For my feet. I. like Don, find heated socks a pain due to wiring. So I opt for the chemical foot liners in my BMW boots, with silk liners and a pait of good wool socks. Those chemical things will last all day and the heat radiates up.
Lastly, a good Baclava that will tuck inside the heated collar of you heated gear. An absolute must have. Keeping the wind off any part of your skin is an absolute must once the temps drop below 25. All bets are off if you don't.
Mike
1998 R 1100 GS
2008 R 1200 R
FrozenRat
Post by FrozenRat »
This may come as a shock to most of you but I rode from the west coast of B.C. and rode to Cartwright Lab/Nfld. and back to my home on Vancouver Island B.C. in the winter .I hit -53 with a windchill of -61 deg. I started Jan.1st 2010 and was home the beginning of Feb.2010.
If you want to see some pics you can follow this link http://stillarat.shawwebspace.ca/photos ... de_part_2/
I did have to get a electric face shield for my BVS2 helmet but other then that No electrics just layered.
AllanCook
Post by AllanCook »
FrozenRat wrote:This may come as a shock to most of you but I rode from the west coast of B.C. and rode to Cartwright Lab/Nfld. and back to my home on Vancouver Island B.C. in the winter .I hit -53 with a windchill of -61 deg. I started Jan.1st 2010 and was home the beginning of Feb.2010.
If you want to see some pics you can follow this link http://stillarat.shawwebspace.ca/photos/
I did have to get a electric face shield formy helmet but other then that No electrics just layered.
Game over. Jeebus.
Allan
Austin
hjsbmw
Donating Member #: 711
Post by hjsbmw »
I suspect this is the definite answer to this thread. I start considering if I really want to take the bike when it is below 30F and haven't ridden in colder temps than low 20s. I am lucky to live in a place where I can ride year round despite of that unmanly disposition.
deilenberger wrote:The cheapest and most effective thing I've got - a silk balaclava. Cost was $5.00
+1 on the balaclava. I use it in conjunction with an open face helmet without a problem. Mine is something thicker than silk. It feels more like a stretchy t-shirt material.
Happy new year to all fellow members.
Harald
2007 BMW R1200R
FrozenRat
Post by FrozenRat »
The only real difficulty that a bike has in the extreme cold is the battery,-20 or colder and they just will not produce enough cranking power so a set of jumpers are a necessity,even a battery warmer failed at the lower temps. and the oil must be changed to a much lighter wt i was tried a 0 wt(Skidoo oil) but once it warmed up it squirted out of the valve cover gasket like a garden hose so i changed up to a 10/20 wt and no problems .I have to tell you all that winter riding is truly some of the best riding that one can do just consider this, not one bug on the whole ride and no lines of tourist RV's blocking the fast lane and it is one heck of a skills builder and with a set of self taping carbide tipped studs in the tires at 20 psi i was riding circles around other automobiles on the icy snowy roads.
If you want some prep tips for doing a winter ride i can gladly help anyone with proper gear and their suppliers as well if you are not aware of this you not only get season rates at motels but you also get if you ask for it a riders discount so rooms are quite cheap,any where from 20$ to 45$ a night.
angellr
Moderator
Donating Member #: 860
Post by angellr »
The phrase NUCKING FUTS comes to mind! Wow!
-Bob-
2014 R1200R - Dark White
2007 R1200R - SOLD
The silk ones are really nice. Thin, stretchy, and WARM. I wore mine while snowshoveling last week during the great Christmas blizzard of 2010.. aside from scaring the neighbors - it worked great.
TAG-Caver
Post by TAG-Caver »
Amazing! What kind of gloves do you use? No matter what I've tried, my fingers freeze below about 20 degrees.
Thanks for the incredible story!
Kevin
2008 R1200R
I rode from Chicago to LA a few weeks ago, it was 18º with heavy snow when I left, and didn't get above freezing for 2 days moving south. My biggest problem was how to deal with the ice filled roads.
I wore a BMW balaclava, Rukka Armas suit (rode the TAT offroad in 115º temps in same suit) , Gerbings microwire jacket liner, Gerbings G3 gloves, and Rukka Outlast long underwear.
My feet were the only dangerously cold parts of my body... I couldn't find my heated socks so I just suffered. Numerous stops at trucks stop showers kept me from getting frostbite.
The G3 gloves with the heated drips kept my hands warm the whole way.
On another note, I am severely disappointed with the new Gerbings microwire jacket.
As a matter of fact I hate it.
I have an older version jacket, but like the 2 I had before it, one of the arms stopped working. Not wanting to wait the LONG turnaround time for Gerbings to fix it I got a new one.
Sucked into the Micro wire Hype.
Seems to me that Gerbings has gone the way of too many american companies and have cheaped out with their "new" China made jackets.
The old ones had nearly 100% coverage, with heating wires all over the jacket, and while it wasn't the most reliable it DID IT's JOB of keeping you warm.
The new one only has heating elements on the tops of the arms, and rectangular patches on the chest, plus a square on the back. I would say it's only about 60% coverage! :evil:
While I did survive my cold ride, I've never been so cold and warm at the same time. The tops of my arms were warm, the bottoms freezing. My back was warm, my kidney area was freezing.
The jacket is so thin, missing the Thinsulate insulation that the old style had. Now, without any insulation the jacket is worthless to wear around the campsite to stay warm, on top of not keeping you warm on the bike.
Beware, if you want to ride in temps below freezing, I would look elsewhere that the micro wire or for the old style Gerbings. I will more than likely be looking for something else or going back to the old one.
BTW, they no longer offer socks, just insoles.
It looks very obvious to me that Gerbings has totally sold out to profits. I can see how it must greatly reduce manufacturing costs to just have a small number of pre made panels to add in, instead of having a insulated liner inside the jacket with wires woven in all over the place.
The insoles must surly be cheaper to mass make then hand woven wires in the socks.
Sellouts!
They used to put so much effort into fitting you correctly with a vast amount of sizes and options because it's important for it to fit correctly, now, they just have basic sizes with the long arm option. I tried on 3 jackets, but none of them seem to be perfect.
Another example of why I think they just sold out to China and profits.
I'm all about companies making money, but to sell a product that does a poor job in comparison, while trying to market it as being better is shady.
end of rant.
My cross country story:
http://www.advrider.com/forums/showthread.php?t=645690
websterize
Donating Member #: 710
Post by websterize »
Joe, you've inspired me to motor to work tomorrow in my Microwire after a month straight of public transportation. Wonderful storytelling, as usual, on ADV.
redwing
Post by redwing »
deilenberger mentioned the silk balaclava ... I like the idea. I was looking for an inexpensive balaclava to go with a "gaitor" I bought. Have not found one yet.
I got a balaclava for thirty dollars (not silk) and by itself is not very good. The gaitor is like a tube sock for my neck with an end cut out and is made from a microfiber like material (very thick). I put the gaitor on covering from mouth to ears then roll the balaclava over to hold it in place while putting on my helmet. Paid three bucks at Walmart for the gaitor. The combination is very warm....to warm for the 60's.
Also for just cool weather I use a bandana. I got the idea from "Long Way Round" and "Long Way Down." One of the riders just tied the bandana around his neck only I put the knot at the back of my neck. It works well for the 60's.
Robert
08' R1200R
Sweet...
mogu83
Post by mogu83 »
Problem I had with a balaclava was, as I rode along the thing slowly moved across my forehead and started to cover my eyes. This forced me to pull over, remove the helmet and reposition the wandering headgear. The balacava now resides somewhere North of Harrisburg on a Pennsylvania backroad.
The point - if you try one of these it would pay to get a good one (I think that's the silk one) I went for a cheap one and ended up throwing my money away.
Right now I'm using a Schampa Facemask which keeps the fog off the shield and the warm in, but it would be nice with something on top of the head. Might give the balaclava another try.
http://www.whitehorsegear.com/schampa-s ... r-facemask
redwing wrote:deilenberger mentioned the silk balaclava ... I like the idea. I was looking for an inexpensive balaclava to go with a "gaitor" I bought. Have not found one yet.
Robert
Google "silk balaclava".. and click on "shopping" (left side of page) - none showed at my price point (I bought these from a friend who bought a crate of them..), but they do start at $10 and up.
http://www.cheapcycleparts.com/products ... -balaclava
http://www.campmor.com/terramar-thermas ... _sku=68166
