This is the short list of what (I think) I know about oil:
- Mineral oil starts with the first number, and use viscosity additives to help keep the oil thick when it heats up. Those additives break down over time. Also, the larger difference between the two numbers (5W-50) means more viscosity additives needed and will wear out faster
- Synthetic is the other way around: the oil is the second number, and the engineering makes it run thinner when cold than mineral oil. There's no viscosity additives required, so in theory the oil is more stable.
- There is a line of thought that you should NOT use synthetic oil until a certain mileage so the engine can break in properly. All I can say is my bike changed over at 12k and it burns a quart of oil between changes. Because the rings didn't seat properly? Maybe. Because I didn't run it hard enough? Probably.
- Water cooled engines should be able to use the same oil all year, since the water cooling and radiator fan will keep the engine temperature relatively stable.
- Air cooled engines have to worry about oil weight and weather due to heat issues.
I've run Castrol GTX 20W-50, Mobil 1 15W-50, and Spectro 20W-50 in my R1150R (current). All seem to work. Just make sure you change at the recommended intervals. I wasn't perfect with my Subaru, and now I have a rod-knock issue (big $$$, but at 187k miles I can't really complain).
I read this yesterday. I'm still digesting the info and some of it is contrary to common wisdom, but it all makes sense...
http://www.ferrarichat.com/forum/faq.ph ... s_articles
