Quick action throttle?
CRazyCam
Post by CRazyCam »
Hi folks.
Sorry if this has been asked before, but I did search and found nothing.
Is there a simple way of fitting a quick action (1/4 turn) throttle tube to an R850R?
regards,CrazyCam
raceratb
Re: Quick action throttle?
Post by raceratb »
i was thinking something similar, it you had a friend with a lathe you could easily create a new distro block wheel where the input wheel is smaller than the one going to the two TBs
CRazyCam
Post by CRazyCam »
Thanks for the suggestion, but it sounds a bit complicated for my limited mechanical skills.
I asked about this because I have a Triumph Street Triple, and, for them, you just go to your local Triumph dealer and buy a throttle tube (the actual twist grip) for a Speed Triple. It fits straight in with only cable adjustment required, doesn't cost much and works a treat.
Anyone know if the likes of the Boxer Cup Beemers had quicker throttles?
regards,CrazyCam
